OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
ramone163
paride4331 wrote:Hi coilbbok,
I tested your issue on 4.39 and 4.38, running an empirical tests (manual stopwatch..) with a 300mb files;
I did not find any big differences like yours and no problems with isolate_selection.
Maybe it depends on some options in Render Setup.
Could you kindly compare your issue using 4.38 and 4.39 with the same Render Setup?
Compared with 4.38 and 4.39. All Render setup is the same.
'Enable Extra Log' is off, all all V1 support is disabled.
The 4.39 is slower x5-x10 times.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
coilbook
neonZorglub wrote:
coilbook wrote:update: only empty max open ok. All existing scenes open slow even with one object in it 1-3 min to open making rendering also slow. Like 2:30 frame to render 2 min is black screen 30 sec to render. every frame. Why so long
Hi Coilbool,
There might be too many log at the moment; Please try to turn off 'Enable Extra Log' in Trouble Shooting tab of Global preferences..
Also make sure all V1 support is disabled..
I hope this will help
I will check other potential performance issues that might have been introduced recently..
thanks I send link to Paride with the scene. Hopefully you can look at it too
coilbook
Hi Paride,
were you able to get my scene? i sent it to you in a private message. If you did not i i will rensend you the link.
I will also test mb for liquids today.
Not sure how to do this :: "ok,
Could you kindly test your CUDA error by exporting your scene to orbx too? "
Seems like 4.39 is even worse with octane viewport. It's been getting slower and slower since version 3. Please try it on my scene I sent you Thank you
paride4331
Hi coilbook,
I can not download the file every time the download stops. Could you kindly use wetransfer and send the link in pm?
coilbook
paride4331 wrote:Hi coilbook,
Hi Could you give me email where to send using wetransfer Thank you
By the way trying to check on liquids mb and viewport is stuck on scene evalation for 10 min already
paride4331
HI guys,
I made a test scene to share.
there is no forest pack, volumes, phoenix etc .. In the scene.
A simple medium / small size scene.
I don't understand what happens with 4.39, because I have not any strange lacks, so I would like to identify the element that causes this issue.
All options like extra log, v1 support etc .. are unchecked.
I also saved it in zip .rps file for 4.39 and 4.38.
I tested this scene on my laptop (i7 16GB gtx 1070), so not a workstation, and I did not find any differences between 4.38 and 4.39 about evaluation time and render.
I think there is some element that when in the scene, it generates this issue.
If you do not have issues with this scene, you could add step by step some element around your usual workflow and see if it creates the reported issue.
https://we.tl/gg1VyeQ4Nr
paride4331
Sent in PM
coilbook
OK
4.39 fixed phoenix mb !
Your scene works fine so there is something in our scenes that make new version very slow.
Version 4.38 - 32 seconds to open octane viewport
Version 4.39 - 9 min 20 seconds seconds to open octane viewport
I just emailed you my scene so there is definitely a bug in 4.39 that makes old scenes open very very slow making rendering 10 times slower per frame
i attached the video with 4.38 version and how fast it is and 4.39 usually stuck with mo response
438 version .mp4
(4.91 MiB) Downloaded 3678 times
coilbook
UPDATE:
seems like bug is connected with amount of mesh in the scene and time it takes to evaluate. We deleted all objects in the scene except car wheels (instanced wheels total 15 mil polys) it takes 4.38 - 5 seconds to evaluate, it takes 4.39 version 2 min 40 seconds Times go down when more mesh/items is deleted. Looks like textures do not affect it.
Also for ver 4.39 isolating object does nothing. having one objects in viewport or the whole scene takes the same amount to open
hopefully it helps.
coilbook
There seems to be a bug if you have multiple phoenux fd grids for multiple fires
it takes a long time to open octane viewport with multiple sims if it can even open. But each sim opens in less than 3-4 seconds
Return to “Releases”
