Akito eGPU + Macbook Pro 13" (2016)
dotcommer
Anyone have experience using an eGPU with one of the latest Macbook Pros? I have a 13" 2016 Macbook pro with 4 USB C ports, and I'm considering moving over to and eGPU and running my GTX 1080Ti through TB3. Thoughts? Does something similar like this work currently with C4D + Octane?
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
Hi dotcommer,
it should work like other eGPU solutions:
viewtopic.php?f=14&t=58895#p304136
The not perfect stability comes from the fact that eGPU is not directly supported by the system, and it is necessary to modify some kext files.
Hopefully, High Sierra should have a better support for this kind of solutions... fingers crossed ;)
ciao beppe
dotcommer
Ok, well I pulled the trigger on a Bizon Box and it should be here this week. So i'll keep this thread updated with my findings.
rmara
At home I built for my daughter an egpu including a Asus 1080ti inside the Akitio node linked to a macbook pro 15 inch from early 2011 and it works perfectly with C4D and octane ... So you should have no problem at all with a macbook pro 2016 ...
frankmci
We've been testing the Akitio Node with Octane/C4D on a few of our cylinder Mac Pros. So far, I've been pretty impressed. I used the following page to get things up and running:
https://egpu.io/setup-guide-external-graphics-card-mac/
Even with the bottleneck of the USB 3>Thunderbolt 2 on the older machines, everything works nicely. The only drawback so far has been that there can be a bit of a delay waiting for all the geometry and textures to load onto the card's VRAM when first viewing the scene. Once it's all on the card, though, it's shweet!
Frank
Yan
I works with Macbook Pro 13" and 15" 2016. You may need to update MacOs to the latest version because they come with a special os build from factory and Nvidia Drivers doesn't work with that build.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
