Hqueue issue
Forums: Hqueue issue
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Hqueue issue
Postby gui2one » Fri Jul 28, 2017 11:19 am
gui2one Fri Jul 28, 2017 11:19 am
Hi, I have an issue when trying to submit Octane Rop to hqueue :
Hqueue job gives this error :
   [/obj/club_dopnet/popforce1/sopguide1/attribwrangle4/attribvop1]
             Problem while synchronizing child node:
             Warning:     Skipping unrecognized parameter "ptrenames".
             Skipping unrecognized parameter "vtxrenames".
             Skipping unrecognized parameter "primrenames".
             Skipping unrecognized parameter "detailrenames".
             Skipping unrecognized parameter "rmanconversions".
   [/obj/fracture_club/filecache1/delete_attributes]
Warning:     Unknown channel(s) "index" converted to spare parameter(s).
   [/obj/fracture_club/filecache1/read_back]
Warning:     Skipping unrecognized parameter "f".
   [/obj/fracture_club/filecache1/file_mode]
[Octane] INFOR: [api] ---------------  Closing the Octane API
Anybody has the same problem ?
Windows 10 |NVIDIA RTX TITAN - 24GB| i9-9900K | 64GB RAM
gui2one
Re: Hqueue issue
Postby gui2one » Fri Jul 28, 2017 12:07 pm
gui2one Fri Jul 28, 2017 12:07 pm
try to find a fix for my issue , I found this , in the plugin manual ,
https://docs.otoy.com/Houdini_Plugin_Manual_HTML5/HoudiniPluginManual.htm#Houdini/The%20Octane%20ROP%20Node.htm%3FTocPath%3DThe%2520Octane%2520ROP%2520Node%7C_____0
Note: Currently you only can have one Octane ROP node in the scene. You will get a Warning message if you try to add two or more Octane ROP nodes to the same scene.
Does this still apply ?
Indeed I have several Rops in the scene in which I have the issue.
gui2one
Re: Hqueue issue
Postby gui2one » Fri Jul 28, 2017 1:03 pm
gui2one Fri Jul 28, 2017 1:03 pm
Arf ... I updated the hqueue installation, That was the issue
everything works fine now
OUPS ... I should have thought of that before posting
gui2one
Re: Hqueue issue
Postby juanjgon » Fri Jul 28, 2017 2:40 pm
juanjgon Fri Jul 28, 2017 2:40 pm
gui2one wrote:try to find a fix for my issue , I found this , in the plugin manual ,
Nope, this is an old limitation. Currently you can have any number of Octane ROP nodes in the scene.
juanjgon
Re: Hqueue issue
gui2one wrote:Arf ... I updated the hqueue installation, That was the issue
No problem ;) If you have any other issue, please let me know.
juanjgon
Return to Bug Reports
Sun Jun 16, 2024 6:39 am [ UTC ]
