Hi.
i was trying to get some jitter motion blur, as you can see on automotive pictures done by a russian arm for example.
The smeary motion blur during the movement isnt perefect straigt or bended ,it has some bumps caused by micro-movements from the camera. And as we a know, it become quite important to get rid of this perfect 3d world if you like to generate realistic stuff....
You can see it here below jitter effect...
https://www.virtualrig-studio.com/#features
So my test in c4d was quite easy, moving object in cinema, camera as a child, mblur acctivated, time sampling per frame bigger then 1. Mblur was there, all good. For the jitter i added a vibrate-tag on the object, vibration was fast but unfortunately no jitter in the picture viewer. Still perfect mblur lines.
Okay, i changed the test. I wanted to know i the vibrate subframes come into occtane.
1 Test. Objekt with vibrate tag and camera (not included). This works. Jitter mblur.
2 Test. Objekt and camera with vibrate tag. This dosent work. No jitter mblur and straight lines.
Is there somebody who has a solluition or had the some problem?
Regards, Hannes
