Version 3.06.2 - obsolete stable
FxDesign wrote: Yes it's what I mean, the refreshing is only working when I close and reopen the node editor.
Do you mean that it will work in your next release ? (and if yes, when will it be out ?^^)
When 3.07 SDK is out and my side is finished. Hard to give exact time.
Ron
Is anyone having trouble with latest nVidia driver release? I am getting constant crashes on even the simplest scenes.
Will report in more detail soon.
Ron
SOLVED: I found that overclocking caused the crashes. This ran perfect before latest driver update but now I need to run the cards at default speed.
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
KeeWe
I'm on 382.53 and getting quiete a lot of crashes on my current project. Not too heavy as well, just dynmics and some particles. Pretty annoying...
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
3dhermit
I don't know of this would be hard to implement , but having the focus picker in LV window actually add key frames to the camera focus depth when auto key is enabled would be great , it changes the value but wont add keys currently, thanks for all your hard work on this!
Tejaycheung
What about OpenCL now? i can't run octane on my 2013macbookpro, and i'm planning to get a new macbook but it's amd.
zoppo
Tejaycheung wrote:What about OpenCL now? i can't run octane on my 2013macbookpro, and i'm planning to get a new macbook but it's amd.
I don't think that this is a plugin problem. You should ask this in the General section.
C4D 2025 | Win10
Tejaycheung
oh, your right. :lol:
nycjunglist
aoktar, any plans to support particle rendering in the Octane Object Tag (like X-particles) for Realflow particles? I could see this being helpful for Realflow | C4D v2.0 that supports granular particles.
Ryzen 9 3950x | 128 GB RAM | 2x 3080Ti
nycjunglist wrote:aoktar, any plans to support particle rendering in the Octane Object Tag (like X-particles) for Realflow particles? I could see this being helpful for Realflow | C4D v2.0 that supports granular particles.
It requires some API to provide access for particle data. There's not yet any api for RealFlow as i could know.
KeeWe wrote:I'm on 382.53 and getting quiete a lot of crashes on my current project. Not too heavy as well, just dynmics and some particles. Pretty annoying...
So try and stay with some older and stable drivers. That's propably not a Octane oriented problem.
Return to “Releases”
