Using HDRI maps for Environment in Octane
TStudio
Hi Paul.
Thank you for making this amazing plugin to Connect Modo and Octane :-) I have great time learning Octane. It is sooo amazing renderer.
I have one problerm with setting HDRI map as a Environment Color. In modo I set Projection Type -> to Spherical and Modo`s redner see it as a image ona a sphere. In Octane this HDRi image is flat... it is seen as projection camera .... how can I change this ?
Hi - can you tell me which release of the plugin you are using pls, and provide a scene for me to download which shows the problem you are having?
Return to “Foundry Modo”
