Getting strange displacement results
mikefrisk
I have a displacement map i've made.
and I have a scene i've comiled of a concrete floor
The concrete is smooth and the displacement map has a mid point of 50% gray. However, when I apply the displacement map to my geometry I get extra noise all over.
I can't figure it out, the image has no noise in it whatsoever.
mikefrisk
I figured it out;
Allthough I rendered my image as a PNG with no compression it was displaying some minor artifacts. I rendered as a PSD and the noise went away.
juanjgon
Are you using the attached image for the displacement? It seems to have a lot of noise! ... but even if you are using a not JPG version, the JPG compression artifacts shows that the original image should have some kind of noise on it.
mikefrisk
juanjgon wrote:Are you using the attached image for the displacement? It seems to have a lot of noise! ... but even if you are using a not JPG version, the JPG compression artifacts shows that the original image should have some kind of noise on it.
Yeah, i feel silly. It works as a PSD.
juanjgon
Ah, OK. Yes, this could be the issue. No problem ;)
kopperdrake
I'm not sure what you've used to create the 50% grey, but there's some variation in your grey values which is causing the displacement issues you're seeing. If you've saved it as a jpeg, which it looks like you have, then it's corrupted your colours as you have chunked data, visible as squares if you select a very narrow range of colours in your image editor. You need to save as a png or other lossless format.
Try this one out instead http://www.mediafire.com/file/tnq3vy7na ... cement.png
- web: http://www.albino-igil.co.uk - 2D/3D Design Studio -
- PC Spec: Intel i9-7940X @3.1GHz | 64Gb | 3 x GeForce RTX 3080 Ti & 1 x GeForce RTX 2080 Ti | Windows 10 Pro 64-bit -
kopperdrake
Oops - beaten to it :D
acc24ex
BTW apparently octane likes displacements in 16 bit then you get smoother transitions where there are gradients etc.
promity
I'm working on an underwater scene. I have only a few objects - the plane of the sea floor and the submarine. I want to add displacement to the seabed. But whatever I tried to do in this direction, I can not do anything. I open the demo scene with the displacement and everything works fine. But if I import this scene into my own scene, nothing happens again.
Well, i found solution - just a question related to scale of textures. My sea floor model 1km in radius. In this regard UV map created huge scale for textures.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Return to “Lightwave 3D”
