camera mapping
Forums: camera mapping
Houdini Integrated Plugin
camera mapping
Postby pingovanderb » Wed Jun 28, 2017 5:31 pm
pingovanderb Wed Jun 28, 2017 5:31 pm
Hey guys, I can read from the documentation that it's possible to camera map textures, however it doesn't say how. It would be great with a screenshot on how to hook it up.
cheers
pingovanderb
Re: camera mapping
Postby juanjgon » Wed Jun 28, 2017 11:07 pm
juanjgon Wed Jun 28, 2017 11:07 pm
The camera mapping can be done using the "Projection Perspective" node, but some additional setup will be needed to match the camera node projection parameters. I'll try to build a sample scene for you.
juanjgon
Re: camera mapping
Postby davidgidali » Fri Jul 07, 2017 5:28 pm
davidgidali Fri Jul 07, 2017 5:28 pm
Would love to see it done properly in Max. All I was able to do is have it use the active camera as the projector - but I need a separate (static in my case) projection camera.
davidgidali
Re: camera mapping
Postby juanjgon » Fri Jul 07, 2017 5:33 pm
juanjgon Fri Jul 07, 2017 5:33 pm
Yes, sorry. I'm still trying to figure how to configure it. Some maths are to be computed to get the camera transformation and projection parameters needed to configure the projection node, and it is not easy. I hope to have a solution soon.
juanjgon
Re: camera mapping
Postby ptunstall » Fri Jan 11, 2019 3:02 am
ptunstall Fri Jan 11, 2019 3:02 am
Hey Juanjo did you ever get this working?
ptunstall
Re: camera mapping
Postby juanjgon » Mon Jan 14, 2019 1:25 pm
juanjgon Mon Jan 14, 2019 1:25 pm
Hmm, I don't think so, but I'll try to investigate it ASAP.
juanjgon
Re: camera mapping
Postby Nicolas_ts » Sun Feb 17, 2019 1:50 pm
Nicolas_ts Sun Feb 17, 2019 1:50 pm
You can do camera mapping through UV texture node. Choose texture type - Perspective from camera, and select your camera. But this method doesn't solve problem with flat environment textures.
Nicolas_ts
Return to Houdini
Sat Sep 19, 2020 10:50 pm [ UTC ]
