OctaneRender 3 for Modo [OBSOLETE]
but, I can see the change projection type button.
This button is always deactivate. I can't touch this button.
Can you post a screenshot of the button pls?
I want to use 2 environment map.
1 HDR map (projection type light prob)
2 sequential file(projection type camera projection)(live action image).
I doubt this is possible with Octane. It allows for a Visible environment and a Lighting environment, and these can be different texturemaps, but I think you want something else? I don't full understand what you are asking.
yoshikai
Hi paul
Thank you for the reply.
I'm Sorry My English.
I want to use Sequence File in Environment Color texture.
I know Can use Sequence File in material.but, I can't use in Environment.
Am I missing something?
And,I want to use projection type of Front projection in Environment.
I attached screenshot.
I uploaded my scene File.
Would you check my scene File?
https://drive.google.com/open?id=0B9g-9 ... 0JvVFd1OWs
BR
Have you tried the approach outlined at the start of this tutorial to gain full access to the Environment Textures?
https://youtu.be/z9h1czU1IaQ
In your scene you have the visible background set to a Front Projection camera. Whilst this is supported by the plugin for materials, it is not supported for the Environment texture. Instead, enable Kernel->Alpha Channel and use Photoshop, Gimp, etc to paste the rendered image over your background.
yoshikai
face_off wrote: In your scene you have the visible background set to a Front Projection camera. Whilst this is supported by the plugin for materials, it is not supported for the Environment texture. Instead, enable Kernel->Alpha Channel and use Photoshop, Gimp, etc to paste the rendered image over your background.
Thank you paul.
I Will try it!
LFedit
3.06.2 support? Is this available somewhere? I can't get my network rendering to work. We upgraded to 3.06.2 in the Downloads at the top of the page, there is standalone, then our c4d plugin, but not one for modo... Is this in the works? I can't really go back to 3.06.1 as the rest of the studio and c4d users have moved forward...
Win 10, Threadripper Pro, Dual 3090s
I have made some changes to the plugin which require a change to the Octane API - which will hopefully be in the next Octane release. So a full release of the plugin is not currently possible. However is you need a WIP release for Windows only - I can provide this built with Octane 3.06.4. Would that help?
LFedit
Oh gotcha, I will keep my eyes peeled for the next release then.
I don't think that will help me much right now. Everyone else is on 3.06.2 and the farm is too. I just rolled back 2 of the nodes, at least that is better then nothing.
Do you have any time frame of when all the versions will be the same? Standalone, C4d and Modo?
It is rare that I would not do a Modo plugin release for an Octane release - however as I'm half way through a change that needs the next Octane version 3.06.2 and 3.06.3 got skipped. And usually the C4D plugin is also available for the latest Octane version - but perhaps because 3.06.3 and 3.06.4 were so minor, there has been no release. So I think all will be in sync again once the next Octane release is available.
LFedit
Do we know when this might be coming out Paul? My coworker and I decided to go back in versions to match up. But now Modo doesn't have a 3.06.2 and c4d does and C4d doesn't have a 3.06.1 and Modo does...
What version would we have to go to?! We have a lot of rendering coming up...
Uhlhorn
The download URL for Modo 901/902/10.1/10.2 (OSX) on the first page is defect. ;-)
Return to “Foundry Modo”
