How do you reset the Octane Render Viewport?
GraemeH
Hi Paul,
Is there a way to reset the Octane Render Viewport to your main monitor, when you originally had two monitors but only have one now??
I moved to a single monitor recently and noticed that the Octane Render Viewport wasn't showing up when I opened up Rhino. So I had to reconnect my previous monitor to actually see it and move it over to the main screen.
Just wondering if there's a better way of resetting the viewport to your main screen.
GraemeH
Thanks Paul for the quick reply.
There's nothing you can add to the plugin to force that window to the main screen? I know it's probably a rare occurrence.
What other info does that config file have that might get trashed at the same time?
That config file has all the info in the plugin Configuration/Setup window - so take a screenshot of it first if needed.
Return to “Rhinoceros 3D”
