I just wondered if it might be possible to look into the following:
1)
Feature: Have a "reset to default" when right clicking a setting in Octane render settings.
Expected behaviour: It would be awesome to be able to revert back to Octane's default for individual setting when changing things like Ray epsilon, filter size etc.
2)
Feature: Scroll wheel to move up and down Octane settings.
Current behaviour: Currently if you use the scroll wheel in Octane render settings, it changes the kernel selection.
Expected behaviour: Instead, would it be possible to make it so that the scroll wheel scrolls up and down the menu as with other panels in Cinema?
3)
Feature: Keep all axes unified when using Lock Aspect Ratio in Transform node. (I don't know if there is a benefit to the current implementation but I always find myself wanting the following, and never the current behaviour).
Current behaviour: If you turn on the Lock Aspect Ratio switch, and then move the slider to a new value and then turn the switch off again, it only remembers the new X value and Y and Z stay the same as they were before you turn the switch on. Eg. Start with X, Y and Z all at a value of one. Then turn on the Lock Aspect Ratio switch and change the value to 2 which moves all axes in unison. If you then disable the Lock Aspect Ratio switch, only X remains at the new value of 2 and Y and Z both revert back to 1 (the previous value).
Expected behaviour: Make all 3 axes remember their new relative value when turning the Lock Aspect Ratio switch off.
Hope this doesn't sound too picky! Just things I use a lot which would help keep the flow going
Kraig.
