OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
s3d-weyrauch
You are really fast, not as Graphisoft. I am waiting for the BIM-Cloud, it would not be released yet. If I have something, I will let you know.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
BfPuVAK
Hey Paul,
thanks for the really fast ArichCAD 21 plugin :D
(up to now: no problems!)
Many greetings,
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
Jasonr
I get a message of outdated add-on in the official latest version Archicad 21.
Any idea?
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
s3d-weyrauch
No idea, I have the same problem...
David
BIM team leader
Can you tell me the ArchiCAD build number and the Octane plugin release number you are using pls?
Jasonr
Archicad 21 3005 INT
and the plugin OctaneRender for ArchiCAD 21 3.6.4.74 (64 bit).
Thank you Paul.
I have download and installed ArchiCAD 21 3005 - and the plugin does not run for me either on this release of ArchiCAD. I am working with Graphisoft to try and resolve this. Sorry for the delay.
I have updated the ArchiCAD 21 plugin installer at the top of this thread. This new version should resolve the issues reported above where the plugin would not load into ArchiCAD21 build 3006.
Following is an experimental release compiled with Octane 3.07 test 3. Make a backup of your scenes prior to saving your scene after using this version of the plugin, in case you need to revert back to the previous version of the plugin.
3.7.0.75
- Compiled with Octane 3.07 TEST 3. See viewtopic.php?f=33&t=62636 for details.
- Reworked the Proxy->OCS/ORBX->Edit button functionality to use the new Octane NodeGraph editor. This is WIP, but allows you to use a gizmo to move elements inside the proxy. Whilst the NodeGraph edit window is open, the render output is displayed in the NodeGraph window, but the Octane Viewport in ArchiCAD is not updated until the NodeGraph window is closed.
- Changed "Linear" projection to "XYZ to UVW" to match Octane Standalone
AC20 -> https://render.otoy.com/customerdownloa ... _64bit.exe
AC21 -> https://render.otoy.com/customerdownloa ... _64bit.exe
Jasonr
So the axis function is only functional for orbx/osc files.
I thought that it would have been possible for obj files that are connected as proxies so micro adjustments would have been possible on screen instead of moving the archicad object and reload.
I hope this will be the next step because from an archicad workflow point of view this is far more optimized.
So we are one step forward.
Any chance for FBX Files.
Return to “Graphisoft ArchiCAD”
