Version 3.06.2 - obsolete stable
fuelnewmedia
Hi aoktar,
We've disassembled the buggy scene and found a solution, but I'm still trying to figure out what the actual problem was.
There was an animated texture with a frame range from 812K to 812K. Maybe this was causing the memory leak. The strange thing is that this texture wasnt applied to any object...
Will get back to you with a test scene when I have time to narrow down the error.
Until then, thanks again for your quick response times :)
Best regards,
VVG
Live DB does not scroll down the shaders. (128*128 size icon)
Search toolbar works partially. Try searching in the Misc section of the x-ray shader (XRAY)
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
artdude12
Does the Standalone 3.06.4 have any other impact on the C4D plugin (at 3.06.2) other than network rendering?
Just wondering.
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
Hi artdude12,
since they are based on different SDKs, they cannot work toghether. You need to stay with Standalone v3.06.2 for now.
ciao beppe
artdude12
OK. Thanks.
ChrisCore
unfortunately I´m using a hackintosh with YOSEMITE (cuda 7). Is there any chance running 3.06 without cuda8?
Upgrading to a newer OSX Version is currently no option.
DinoMuhic
ChrisCore wrote:Hi,
nope
FxDesign
Hello Aoktar,
Any chance to make ctrl+z (on windows) to work in the node editor ?
FxDesign wrote:Hello Aoktar,
It works actually but there's a refresh problem on side editor. Do you mean that? It's fixed on my development builds if you mean that.
FxDesign
Yes it's what I mean, the refreshing is only working when I close and reopen the node editor.
Do you mean that it will work in your next release ? (and if yes, when will it be out ?^^)
Return to “Releases”
