Yes pls Eric.Do you want the whole .3dm file?
This is a bug, which will be fixed in the next release.Attached is a pdf of the Materials Editor. See where it says Scale Texture (upper middle above the Diffuse portion). That's what I was clicking on to modify the textures. A little slider pops up and it work just fine ... but the result does not persist from work session to work session.
You need to modify the UV mapping of the geometry. Enable Octane->Settings->Render Passes->UV coordinates, then select the UV coordinates pass in the Octane Viewport to see the UV coordinates on the geometry. You can adjust the UV mapping in the Rhino Properties->Texture Mapping tab for the geometry. You will need to refresh the Octane Viewport after changing any UV's in the Rhino geometry.Now, how do I get materials all on the same layer to run in the same direction on different surfaces?
