Tips for Realism
Forums: Tips for Realism
Tips for Realism
Postby _roogul » Thu Jun 22, 2017 1:35 pm
_roogul Thu Jun 22, 2017 1:35 pm
I've been working on this shot, on and off, for about 3 days now.
Does anyone have any tips for pushing this to be even more realistic. Something just isn't sitting right with me, and I've been looking at it for too long to figure what it is!
All comments are appreciated, but please make them constructive :D
_roogul
Re: Tips for Realism
Postby gah5118 » Thu Jun 22, 2017 7:25 pm
gah5118 Thu Jun 22, 2017 7:25 pm
main things that look off to me are the floorboard and walls. the brick could use some work also. Otherwise the rest looks awesome!
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
gah5118
Postby itou31 » Thu Jun 22, 2017 8:22 pm
itou31 Thu Jun 22, 2017 8:22 pm
Perhaps, some dirt and noise in the material nodes...
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
itou31
Postby grimm » Thu Jun 22, 2017 9:42 pm
grimm Thu Jun 22, 2017 9:42 pm
A little bit of dirt and dust would be good, also I think if you have a shaft of sunlight coming through a window would do wonders as well. :) Also the framing of the image is strange, I wouldn't cut off the chair at least.
Jason
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 460.56
grimm
Postby _roogul » Fri Jun 23, 2017 8:09 am
_roogul Fri Jun 23, 2017 8:09 am
Looks like I'll try adding some dirt / dust in then! Thanks for the comments, hadn't even thought about adding that in.
_roogul
Postby _roogul » Fri Jun 23, 2017 8:12 am
_roogul Fri Jun 23, 2017 8:12 am
grimm wrote:A little bit of dirt and dust would be good, also I think if you have a shaft of sunlight coming through a window would do wonders as well. :) Also the framing of the image is strange, I wouldn't cut off the chair at least.
Jason
I think a bit of context with my framing choice would of helped. This is a draft for a flooring company, so the focus really is the flooring. That explains the weird crop of the chair!
I'll try adding some dirt / dust into the materials now. Will definitely have a play with some sunlight beaming in from the left side.
_roogul
Postby Marvez » Fri Jun 23, 2017 3:23 pm
Marvez Fri Jun 23, 2017 3:23 pm
nice start
I feel doesn't need dirt.
- something about the diffuse materials seem flat - typically most surfaces of a home have some sheen from paint or wear.
- maybe a little more floor in foreground
-some reflections in glass of framed pictures
-when I look closely at the chair I see some nice displacement /bump of the wood texture with a sheen; similar effect should be applied to the floors and base board
best
wm
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez
Postby Marvez » Fri Jun 23, 2017 3:30 pm
Marvez Fri Jun 23, 2017 3:30 pm
and upon second look what are using direct light or path tracing? use PT and yes play with light to add volume to the spaces , ie globe looks flat in the scene
Marvez
Postby Aww167 » Sat Sep 02, 2017 9:06 am
Aww167 Sat Sep 02, 2017 9:06 am
I know this is pretty old now (June), but just wanted to post a reply because it's such a striking image. The main issue for me is the composition of elements. You have the globe and pictures against the wall and somewhat away from the main focus of attention, even though they are by far the more colorful and interesting image elements and immediately draw the eye. This rather leaves them fighting for attention with the expanse of floor which occupies far more of the image area, yet lacks in color detail and therefore is less interesting by comparison. The pictures, globe, chair and lower wall are all beautifully rendered and to my mind, far more deserving of being the main focus of attention. Wouldn't re-framing the image from a slightly different perspective i.e. less floor and more of the individual items help balance things more aesthetically and produce a more satisfying image? Otherwise I feel you're left struggling to make the floor look more interesting (real?) when there's nothing intrinsic to help achieve this, except perhaps use of lighting, dust etc and possible reflections to add interest and depth.
Aww167
Postby Builtdown » Sat Sep 02, 2017 10:19 am
Builtdown Sat Sep 02, 2017 10:19 am
Is this picture supposed to be an advert for parquet or something? If not, why is 60% of the picture just floor and everything else at the top of the picture?
The floor texture looks too large and the chair looks too small.
Builtdown
Next
Return to Works In Progress
Users browsing this forum: No registered users and 14 guests
Tue Apr 23, 2024 10:36 am [ UTC ]
