"keep continuity" for DISPLACEMENT?
cirasa
Hi cirasa,
with OctaneRender displacement you need to change the Phong angle to 91°, or disable the Angle limit option in the Phong tag of the mesh with displacement.
Remember to play with the Mid Level value based of the image used to define where the displacement have to start.
ciao beppe
Jolbertoquini
bepeg4d wrote:Hi cirasa,
ciao beppe
Well this doesn't fix the issue, is actually pointing a problem with displacement in other render we don't have, I think should be review the actual displacement node is breaking all geometry and making the usage of SSS impossible to be accurate. only with a really small displacement and then is pointless better use a nomal or a bump.
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Hi Jolbertoquini,
what about the uvs?
With OctaneRender displacement you cannot have overlapping uvs.
ciao beppe
coilbook
I agree. Please make it where displacement keep mesh intact and light does not shine though it. It is hard to work with 3D displaced objects.
NVN
+1
itsallgoode9
bepeg4d wrote:Hi Jolbertoquini,
what about the uvs?
ciao beppe
wait, what?! really, you can't have overlapping UV's? is this new or has it always been like this?
I've had some random problems with displacement in the past that I haven't been able to diagnose and now i'm wondering if that was the cause of it.
Terryvfx
Isn't Otoy working on a revamp for displacement? I hope they add a Keep continuity option to it.
Hi Jolbertoquini,
I can confirm that displacement has never worked with overlapping uvs.
ciao beppe
cirasa
are you trying to solve the problem?
Return to “Commercial Product News & Releases (Download here)”
