Animate Entire Environment
Notiusweb
Hello,
I took Beppe's Animate Value script and am trying to accomplish the following-
His script:
Modify (1) a single float value, from (2) start to (3) end, over (4) time period
I am trying to:
Modify (1) all pins in an entire environment node, from (2) start to (3) end, over (4) time period
local AnimateValueScript = {}
local mStart
local mStop
local mSec
local mOutput
function AnimateValueScript.onInit(self, graph)
    graph:updateProperties({name = "AnimateEntireEnvironment"})
    -- create input linkers
    local inputs = graph:setInputLinkers
            type            = octane.PT_ENVIRONMENT,
            label           = "Start Value",
            defaultNodeType = octane.NT_ENV_DAYLIGHT,
            defaultValue    = 1
            label           = "End value",
            defaultValue    = 1
            type            = octane.PT_FLOAT,
            label           = "Time in seconds",
            defaultNodeType = octane.NT_FLOAT,
            defaultValue    = 10
    mStart      = inputs[1]
    mStop       = inputs[2]
    mSec        = inputs[3]
    -- create output linker
   local outputs = graph:setOutputLinkers
                label = "Animated Value",
                defaultNodeType=octane.NT_OUT_FLOAT
    mOutput = outputs[1]
end
function AnimateValueScript.onEvaluate(self, graph)
    local startVal  = mStart:getInputNode(octane.P_INPUT):getAttribute(octane.A_VALUE)
    local endVal    = mStop:getInputNode(octane.P_INPUT):getAttribute(octane.A_VALUE)
    local totalT    = mSec:getInputNode(octane.P_INPUT):getAttribute(octane.A_VALUE)
    local Output = octane.node.create
            type       = octane.NT_ENV_DAYLIGHT,
            name       = "Ani Value",
            graphOwner = graph
    Output:setAnimator(octane.A_VALUE, { 0 }, { startVal, endVal}, totalT[1])
    octane.changemanager.update()
    mOutput:connectTo(octane.P_INPUT, Output)
    AnimateValueScript:setEvaluateTimeChanges(true)
end
return AnimateValueScript
When I modified script to accomplish this environment pin morphing, it is telling me I can't index a nil figure. I imagine it has to do with the table not being able to take in all the data from the entire environment node's pins via the command I am giving it.
But I am now curious, is this even possible, to set an entire placeholder environment node (all floating & boolean sub-nodes and all), and then have that be read and fed into the active environment node channel, with the timeline, like Beppe was able to do with the single float value.
I was able to establish the physical shell (I have to select Daylight or texture), and it connects out to the environment node of a render target, but it never establishes the animation timeline like the working script from Beppe.
If anyone can give some insight that would be great. I am curious if I cannot do this at all, and what might make this work.
THANKS!
Notuiusweb
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Maybe I need to instruct the script to create the nodes, and not just reference them?
I see that is a common thing that comes up...
I guess only time will tell...Or will it...yes, it will. No wait...it might not?
Hmmm...Does anyone know a Lua script to go into the future?
Plugs: Enterprise
grimm
This usually means that you are trying to access a variable that doesn't exist. I would double check your code for misspellings or where you might be attempting to assign data of different types.
Jason
Notiusweb
Jason
Hello, thank you very much for giving some feedback to me! I appreciate that very much.
I understand what you are saying about the misspellings. Beppe wrote the base script, and I know that Octane developers and team do in fact have terrible spelling, so I will double check this. I also understand what you are saying about assigning data of different types. I thought I was being inclusive and unbiased in this approach. But I now realize I may inadvertently have been the prejudiced one in this equation...
Maybe there is some force that does not want me to animate, or "change" the environment. Maybe it is all a neo-fascist conspiracy to hush those bringing attention to the environment, but I will put this aside for now.
What I see is that the Environment node is not "a value", as in a single value, but rather an array of values, or a list of values, a collection, a grouped package of some sort. I think I need to look into how to get the linkage from the node to the animator, by having all the pins of data be connected, welcomed, if you will...A big happy family of values sitting at the table of data. I will use all of my psychic powers and press on.
Thank you for your explanation!
-Notiusweb
Plugs: Enterprise
Notiusweb
LOL...
In progressing and testing I came up with a script that crashes Octane, predictably as soon as it is run...
Wonderful!
Plugs: Enterprise
Notiusweb
Closing in...
My issue is that I know how to link a single value, but not the node in its entirety. Meaning, I wanted to link the environment node itself as the single 'value'.
Well, take a look at this:
CarCombiner(3).mp4
(5.07 MiB) Downloaded 4659 times
Plugs: Enterprise
Return to “Lua Scripting”
