OctaneRender® for 3ds max® v3.06 - 4.33 [OBSOLETE]
Tema
paride4331 wrote:HI Elvissuperstar007,
I made PMC test with your scene,
It seems to confirm my previous test.
I honestly do not know what to say.
You could make a clean uninstall of Nvidia drivers before installing latest Nvidia drivers:
http://www.guru3d.com/files-details/dis ... nload.html
And do not install any CUDA toolkit.
I don't know why too... All tests done in one day. Changed only version of Octane. I'll try to do a clean install of video card drivers.
Thank you.
paride4331
Thank you.
Hi Tema,
Which kind of video cards are you using?
Tema
Hi paride4331.
I use:
video card: 2х GTX 1080.
mainboard: ASRock Z77 Extrime4
CPU: i7-3770
operating system: Windows 7x64
Tema
Hi paride4331.
Deleted the video driver, used the recommended program. PMC works are still slow...
paride4331
Hi Tema,
How much Ram do you have?
I own 2 Gtx titan x Maxwell, in few days I will buy 1 Gtx 1070, so I will test again with Pascal.
Tema
paride4331 wrote:Hi Tema,
I have 16 GB of RAM.
I'm in no hurry. The main thing that the speed was not slower in the next version.
If the rate will be as in version 3.05, it will be good. If will be faster then it will be very good.
paride4331
Hi guys,
I tested PMC with Pascal instead Maxwell GPU (Octane 3dsMax plugin 4.34 - 4.33 - 4-30)
no issue reperted.
Tema
Hi paride4331,
I don't know why this result. A problem precisely not in integration. I did a test in Standalone with the same result. If you need more information write. Maybe the next version will be better, but this version showed poor stability of the result on different systems.(((
paride4331
Hi Tema,
I made my test on:
PC Win 7 / i7 5930 - 32Gb / 1 x quadro K620 (Maxwell) / 2 x Evga Titan X Hybrid (Maxwell) / SSD M.2
PC Win 10 / i7 7700HQ - 16Gb / 1 x Gtx 1070 (Pascal) / SSD M.2
Two completely different computers but with the same results.
I think it depends rather on softwares and/or OpenGL applications running simultaneously.
Another cause could be GPUs cooling.
Tema
Hi paride4331,
For each test the conditions were the same. My computer I described above.
If there were problems with cooling the GPU, they were the same.
Applications running in parallel was not, if the application were the application were the same.
If it helps, I mage to do print screen in the Windows task Manager, processes tab, while doing the test.
I already wrote that did the test in Standalone. In order to eliminate the operation of 3ds Max. The result was faster by 6.5%. But the result was worse 4.30, which I did in 3ds max.
Return to “Releases”
