Normal maps
dmodric
I am having trouble with normal maps. I get inverted normal maps on some of the polygons. Triple/double sided doesn't help.
Please help
Thank you.
normal_test2.zip
(603.83 KiB) Downloaded 156 times
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
juanjgon
Are you sure that the polygon normals on those objects are consistent, pointing all inwards or outwards? Let me check the scene.
juanjgon
Well, at least in the cube scene it is hard to say if there is a problem with the normal map. I've replaced the environment for a light just behind the camera to see the normal map shading and it seems fine to me. Perhaps it is only an optical effect in your camera.
Return to “Lightwave 3D”
