Hello ,
I have a little trouble with 3.06 rendering. sometimes, my render is stopping a little bit before ending. I don't understand why. Nothing to do to finish the render, but no problem to press cancel.
I thought it was because i activated "limit visibility to camera" into Itoo Forest pack, but, it is not.
I thought it was because network saving images, but is not.
In my scene i have baked animated car, large terrain and some itoo forest pack scatters.
is this a knowed problems about items used into my scene ?
I precise i have a lot of shots is working fine and i don't know why sometimes a frame is blocking all my render.
I precise another thing i use network rendering of Octane with multiple computers with 4 Gtx 1080 each.
Can you help me please ? Thanks.
g.
[EDIT]
After reboot twice my computer, the render is ok. I never had that with 3.05.3.
I think it's due to a flashing memory problem. Did you ever hear about that ?
OctaneRender® for 3ds max® v3.06 - 4.33 [OBSOLETE]
- paride4331
Hi finkaboutit,
It's hard to say with only this screenshot; I think your issue depends on a Ram limit on your pc.
You could make this test:
Eliminates all Elements render
set max. Tile sample > 1
Waiting to hear from you
- paride4331
Hi coilbook,
I think you've swapped a function for another.
https://knowledge.autodesk.com/support/ ... F-htm.html
https://knowledge.autodesk.com/support/ ... A-htm.html
https://knowledge.autodesk.com/support/ ... 5-htm.html
- Elvissuperstar007
- Contact:
Re: About W Hair and Ornatrix ( Tips and Tricks questions)
Hi guys,
I think Octane 3dsMax + Ornatrix has some issues.
I tried to export to SA and issues seem to be too.
viewtopic.php?f=24&t=59458&start=10
Hi guys,
- andrey.krivulya
- Contact:
Hello, dear OTOY Team.
So in this version I have a problem with render passes... For example I want to check noise and I added noise pass to the Render Elements, but when I select Noise Pass in Octane Viewport - all what I rendered early - lost, and Octane start render again... So I have this bug with all passes... In Octane Standalone - everything is ok.
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
- Elvissuperstar007
- Contact:
Yes-yes I have the same error problem with render passes
- Test.rar
- (80.12 MiB) Downloaded 305 times
- paride4331
Hi andrey.krivulya,
thanks for your report about render passes in render Elements,
I'll send your issue to developers.
- andrey.krivulya
- Contact:
Thank you very much, Paride =) Have a nice day =)paride4331 wrote:Hi andrey.krivulya,
- neonZorglub
Hi! Next version (4.34) will support Max 2018; Should be released in the next few days..octanegraff wrote:Is this version compatible with 3DS Max 2018 yet? I am not finding any documentation stating that it is.
thank you
