Phoenix FD 3.0 particle usage with Octane plugin 4.33
paride4331
Hi darkline,
I tested 3dsMax 2014 product version 16,0 Service Pack 5
darkline
octane problems.mp4
(49.27 MiB) Downloaded 5057 times
have at look at the attached video. Some interesting things going on here.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
darkline
last video. This shows me opening an old file which previously did render correctly, and now resimulating. You can see where it renders the old cache files motion blur appears, but dissapears when overwritten with the new cache file.
I just cant seem to diagnose exactly where this is going wrong.
phoenix 2.mp4
(20.28 MiB) Downloaded 5060 times
paride4331
HI darkline,
I made some tests about your issues, using 3dsMax 2014, everything seems to work.
I created new simulation and no pre-cache, MB seems to work as well.
Did you install the latest 3dsMax 2014 SP?
darkline
I do have service pack 5 installed unfortunately.
there is a service pack 6 now, i may try that
paride4331
Hi darkline,
You could uninstall nvidia drivers using:
http://www.guru3d.com/files-details/dis ... nload.html
And reinstall the latest drivers.
Do not install Cuda drivers or toolkit.
darkline
just done all that and it's made no difference. :-(
Can you do me a favour and download the attached file. I know all phoenix settings will reset because its a demo, but see if you can use the attached file to simulate with the default liquid settings and get motion blur. This will at least determine if something is going wrong with the file. I cannot get motion blur to work at all with this max file.
thanks
for otoy.zip
(23.54 KiB) Downloaded 304 times
paride4331
Hi darkline,
Octane 3dsMax plugin works well, just having to consider Units of measurement.
darkline
Thank Paride,
Then I'm lost, it works sometimes for me, but not others, even when following the same steps each time. Maybe I'll reinstall max2014 completely.
darkline
Hi Paride,
how do I apply an octane material to the wetting or wet map in the liquid?
Return to “Autodesk 3Ds Max”
