Which feature do you need the most?
Region Render
139
6%
Network render
84
4%
Render Passes
238
11%
Hair&Fur
286
13%
Particles
228
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
87
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
369
16%
Mixing of daylight and HDRI environment
212
9%
Subdivision surfaces (OpenSubDiv)
80
4%
Multi UV channels
129
6%
Rounded edges
130
6%
Total votes: 2242
Notiusweb
An ability to check/uncheck a "mirror/flip image, horizontal/vertical" box, for any type of image brought in (ie as a texture).
I know I can do this on my own in an outside program easy before I bring in into Octane, but I want to be as lazy as possible.
Plus it would be nifty to see results on the fly and compare the 2 results of an image mirrored/flipped as a texture.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
FrankPooleFloating
Checkboxes could be useful, but you can do this with UV Transform. Pop -1 into either/both S.X or S.Y. You can do it this way bro, and we can still call you lazy, if you want. ;)
Notiusweb
FrankPooleFloating wrote:Checkboxes could be useful, but you can do this with UV Transform. Pop -1 into either/both S.X or S.Y. You can do it this way bro, and we can still call you lazy, if you want. ;)
Ah, -1...My favorite number!
And I didn't even learn that on my own. You went through the effort of telling me.
How's that for Lazy.
Plugs: Enterprise
Notiusweb
An alpha material? Meaning, it would alpha anything "behind" that material too (such as a texture or daylight background), where a composited image behind/underneath it would be visible.
Plugs: Enterprise
Tutor
Location: Suburb of Birmingham, AL - Home of the Birmingham Civil Rights Institute
Notiusweb wrote:An alpha material? Meaning, it would alpha anything "behind" that material too (such as a texture or daylight background), where a composited image behind/underneath it would be visible.
Because I have 180+ GPU processers in 16 tweaked/multiOS systems - Character limit prevents detailed stats.
aimning
Hope to join the X-particles default material support as soon as possible :D :D :D
jerzer
It would be great to have a subsurface multiplier like in Modo to help creating cool glowing effects (or like Light multiplier in VRAY). With Octane SSS many times I find I can't reach the intensity I want for the type of artwork I do. See image below.
Windows 10 - i7 6850k @ 4.2GHz - Asus X99-E WS - 64gb DDR4 - 2x 1080 GTX + Titan GTX
jerzer
Hi jerzer,
finally I have found the time to look at your scene.
Here is my version with only one Specular material instead of a mix material.
If you use a Gausssian spectrum node, instead of an RGB node, you can easily use a value greater than 1 in the power pin. Playing with the Phase value, helps to reduce the transition between the colors:
SSS-b2.orbx.zip
(19.9 MiB) Downloaded 392 times
In general, with Specular material and SSS, better to switch to PMC kernel, instead of Path Tracing.
Happy rendering,
ciao beppe
