OctaneRender™ Standalone 3.06.2
coilbook
will all these material be possible in version 3.1 like vray has https://youtu.be/BXHxaApBcFs they are all porcedural
enricocerica
bepeg4d wrote:Hi Enrico,
just to clarify, you want random values for position, rotation, scale of the instances, or random values for material settings of the instances?
ciao beppe
Not only, but also for any other values like gamma, power and whatever value which could be used to make materials varying.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
abstrax
DinoMuhic wrote:Hey,
when can we expect the dirt node to work again in the emission channels? It used to work but its broken for a while now.
Is it being worked on?
It's a limitation of our current SPT (streaming path tracing) architecture and would require some major changes to make it work again. We are already in the middle of some major changes to implement OSL support and we will look into this after the main OSL work has been finished.
abstrax
coilbook wrote:will all these material be possible in version 3.1 like vray has https://youtu.be/BXHxaApBcFs they are all porcedural
The new OSL material system should allow a lot of crazy stuff and we will try to support existing material databases as much as possible. We will see what exactly can be done and when, after OSL has been matured enough. Yesterday we got to the point in the OSL branch that all references to the old material system got replaced by the OSL implementation. It will still take some time until we get the new material system ready for a test release, but it's good to see some tangible progress after lots and lots of work.
rrbarb
!goDaddyGo!
coilbook
VDB flames questions
in the picture you see some controls to control flame brightness. PleASE PLeASE make it simpler. I am lost what should be left and what should be adjusted for a real brightness flame. Please make a video tutorial or help where to begin and what should not be touched. There
calus
abstrax wrote: Yesterday we got to the point in the OSL branch that all references to the old material system got replaced by the OSL implementation.
Does this mean that in 3.1 every legacy Octane nodes use OSL under-the-hood ?
Pascal ANDRE
Goldorak
Do you mean that in 3.1 every legacy Octane shading nodes are replaced by an OSL implementation of these nodes ?
If the results from a 3.1 user's perspective are practically identical to 3.0, then yes, it's very much a possibility.
If you are also thinking that re-writing all of Octane 3 in OSL would be a crazy amount of work, that's true. This is why it wasn't released a year ago in 3.00. Testing and validation are next, and we'll get a better sense of how the final implementation will work.
Going deep with the new GPU shader compiler (other shader languages can follow OSL) means Octane is more than just a GPU renderer , it's a full stack rendering framework that entirely novel GPU renderers can be built on top of (e.g. Optix, Mitsuba) - all from the node graph. It's possible to develop biased photon mapping/irradiance cache (OSL + render to texture + reverse baking camera), or entirely new BRDF or SSS models dropped in from the latest Siggraph paper.
Re: the original question about VRscans - an OSL shader can definitely handle such BTF style material captures. In fact, that's how we will support even more complex lightstage captures in 3.1.
When we deliver ultra high quality material scanning to customers like ADSK (an investor in OTOY) it goes through our Burbank LightStage. LightStage outputs a non-proprietary open source BTF or 8D reflectance field texture. With 3.1 we can pack this output into ORBX with all the OSL you'd need to render it + share it on LiveDB, which we will do.
We're going to start with complex multi-layer LS scans (such as skin) first: e.g an Octane ready ORBX of the LS skin data provided to Epic for the new UE4 human head template: https://docs.unrealengine.com/latest/IN ... Character/
calus
WOW,
this is kind of my dream implementation coming true.
And well yes I understand, very long development time and huge amount of work for this, totally make sens,
but worth it thousand of times as it basically remove any possible limitations for the renderer,
and is also a complete game changer for DCC plugin integration.
Pascal ANDRE
Elvissuperstar007
Can not save material bug local DB http://silverwing-vfx.de/free_stuff.html
The file ORBX itself is located D:\Silverwing_Octane_Materials
Return to “Commercial Product News & Releases (Download here)”
