How to apply Octane Scatter to selection?
Aleksei
Is it possible to apply Octane Scatter object to surface selection somehow?
Because I cannot find this option in the attributes panel:
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
Utiibs
Hey bud, if I'm understanding your question correctly all you need to do is drop object into that surface channel. so you have your scatter you have a plane and you have a sphere if you want the sphere to be scattered accross the plane. click scatter(already parented to sphere) drag plane into the surface channel.
Aleksei
Thank for your reply.
I want not just scatter a sphere across the plain, scatter it across
Some defined polygons which are marked by polygon selection tag.
Unfortunately, I'm not near the computer now and can send screenshot only later today.
fatrobotsneedlove
Use a vertex map. Under parameters, halfway down the picture you attached.
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
Aleksei
Thank you! That's even cooler than point selection :)
mbutler2
I recently learned from a Beeple video how much faster Octane Scatter is than cloner. Pretty awesome.
