tilt shift effect in animation
Carrara (Integrated Plugin developed by Sighman)
lecube
I'm trying to simulate a tilt shift effect on basis of a distorted photo and animated camera focal depth by keyframes.
When rendering a single frame everything works fine.
But when rendering as a movie in the carrara render room it doesn't work.
What settings do I miss?
protovu
Hi Lecube,
Perhaps you have tried this, but you may want to:
-place an invisible object (sphere) or Target Helper Object in your scene at the location you want your camera focus.
-Then select your camera and give it a Point At Modifier.
-In the Modifier drop down, select the object.
tschwenke
Don't no really know what you mean by "But when rendering as a movie in the carrara render room it doesn't work."? What doesn't work?
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Sighman
You are using an old version of the plugin. Please try installing the latest version and let me know if the problem is still there.
viewtopic.php?f=79&t=56881
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
tschwenke
Apparently Simon does :)
lecube
Updated and .....problem solved! Thanks.
By the way (changing topic here): when closing the Carrara scene before closing the Octane render window carrara crashes, every time.
No big deal since I can change the order of closing the windows but.....maybe there is a reason I don't see and I can fix this.
protovu
....and I thought I was the only one. Yes, crashes on close unless I exit the Octane viewport first.
Like you, not a big deal, but was curious as to why.
Return to “Carrara”
