OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
the file you have posted seems to relate to the Revit Plugin?
Fixed now - thanks Dan.
s3d-weyrauch
Hi Paul,
I have to report a bug.
If I change the Y-Rotation of a Texture-Environment, than I have problems with importance-sampling, it misses suddenly the setting "behind the curtain". The importance sampling is on, but it seems to be not.
If I check the importance sampling out and on again, than everything will be fine again untill I change the Y-Rotation.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Hi David - this is fixed in the next Octane release.
Daniel_Ward
I noticed the same thing, thought I was going a bit mad.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
I have updated the installers at the top of this thread with:
3.6.1.73
- Compiled with Octane 3.06.1
- The Reload proxy button now applies any "Face Camera" calculations
- The Reload proxy button now also works for OBJ proxies, so can be used to re-position a proxy after moving the proxy host
- Fixed issue where re-linking a missing proxy source file was not saving the new file name/folder back to the ArchiCAD scene
- Clicking the Reload button to reload a proxy now also reload the SCV scatter file
3.6.1.74
- Fixed bug with the proxy Reload button introduced in 3.6.1.73
Jasonr
Thank you Paul for the fast update.
Is there any possibility to be able to select more than one proxies, move them and have the option of a reload for all these moved proxies or is this a limitation between archicad and the plugin???
Thanks.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
If you want to reload multiple proxies, you can just Refresh the scene.
rappet
My guess is the request is a feature to reload only the selected proxies, and not the total scene... To save time.
Which would be awsome, but I think hard to realize, right?
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
I think in a lot of cases it will be easier to reload the scene than to remember which proxies you moved and then select them all and then reload them. I am trying to understand the benefit of this change before I invest time in determining if it is viable.
Return to “Graphisoft ArchiCAD”
