OctaneRender® for Maya® 3.06 - 10.21 [OBSOLETE]
Moderator: JimStar
BK
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octane Render™ Standalone on your machine.
For network slave and daemon please download the Standalone installer here:
viewtopic.php?f=24&t=60772
CHANGES SINCE THE PREVIOUS VERSION
  • Urgent fix on texture load setting with reference object.
Bug fixed for:
viewtopic.php?p=313153#p313153
Windows
DOWNLOAD
OctaneRender for Maya10.21
OctaneRender for Maya DEMO 10.21
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.21 Linux
OctaneRender for Maya DEMO - 10.21 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 10.21 OSX
OctaneRender for Maya DEMO - 10.21 OSX
Kind Regards
bk3d
renmaxhb
BK,
thanks,thanks :D reference works well :lol:
itsallgoode9
thanks for the update!
renmaxhb
another bug,poly will lost matrerial when copy abc poly at instance :(
test
test
case
case
renmaxhb
BK,
quick fix :D ,go go go
Jolbertoquini
renmaxhb wrote:BK,
where is the fix???
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
renmaxhb
Jolbertoquini wrote:
renmaxhb wrote:BK,
where is the fix???
Ask for release the quick fix vision :(
renmaxhb
BK,
quick fix :D ,please
Jolbertoquini
Hi Guys,
here some bug on the plug...
Before we was able to "duplicate" nodes and shaders while "IPR" running and changed then and link the duplicate node in other shader or same one with changes.
Now with the currently plug we can't nodes is not recognized and when we stop "IPR" mode and re-run still not recognizing the duplicate nodes something maybe be broke then to work I need close Maya so Octane flush the cache and start the render with the duplicate nodes...the only way to work is creating complete new nodes and then use presets but doesn't work with all nodes.
Please would be great to have a quick fix for that is just making slow our workflow then before, as you can understand if we not able to duplicate nodes is a big waste of time.
Best,
JO
itsallgoode9
Jolbertoquini wrote:Hi Guys,
Best,
JO
Yeah, i've been having some sort of similar problem as well. haven't been able to pin it down but something is up with Octane not recognizing material changes.
Return to “Releases”
