Hi, Aoktar. Is it possible to fill any c4d object with Volume ?
So the object behaves as Volume generator.
I think it's can be done in LightvVawe integration.
Thanks.
P.S. Never mind. It's possible
UPD. It is working only with sphere object. Meh...
No but only you can put some spheres under volume object and it will reshape the voxels. It's an experimental feature. Other than this you should generate some vdb volumes in another software and use that.
