Hello community,
I'm heading towards buying Octane (Standalone + C4D Plugin). Have been digging the subject for a while now and started to have doubts about if the move has sence.
Setup:
- i7 5930K @ 3.5 GHz
- 1 x EVGA GTX 970 SSC 2GB
- 32 GB RAM
First question: will this 1xGPU be enough for some time or i need to consider buying another one to really feel the difference (currently working with physical render).
Second question: how does the licensing work exactly (been looking for the anwser in FAQ). If i buy a standalone + plugin version, install in on one PC and then for example: change the version of C4D / upgrade the hardware / change the working place, will i be able to activate it again? Does it make any connection to the software (in this case C4D) that i am working in?
Best regards
Doubts before getting the license
Hi, Gieroj.
Welcome to OTOY forums. Let's answer some question You left here!
So it all depends on Your needs.
One thing to recommend though. I would get subscription OctaneVR & try out for start - You will understand how fast it goes or how big of a scenes You can fit inside. Learning scene optimisation would pay of on the long run, so having a smaller GPU with less of VRAM could be an advantage if You choose to look from certain perspective.
Let us know if You would have any other questions.
2GB GPU is not very big, but since OctaneRender has out of core texture feature allowing You to keep maps in system RAM & things like instances allowing to save quite some vram if You have repeated geometry..I would say even 2GB card would be good for a start (uness You start throwing complex, multimillion car model or complex trees..)gieroj wrote:First question: will this 1xGPU be enough for some time or i need to consider buying another one to really feel the difference (currently working with physical render).
When You have licence You can use it to any computer You like. So if You start working on Your machine at home, You can turn of & it would deactivate automatically. Then You can use the same account with licences on other machine. So, do not worry about licences tying up to machine or specific packages.gieroj wrote:Second question: how does the licensing work exactly (been looking for the anwser in FAQ). If i buy a standalone + plugin version, install in on one PC and then for example: change the version of C4D / upgrade the hardware / change the working place, will i be able to activate it again? Does it make any connection to the software (in this case C4D) that i am working in?
there's no free OctaneVr version anymore, but You can rent a copy (using subscription service) for 20$/month. Let us know if You would have more questions.gieroj wrote:Thank You for the reply @glimpse. I have made a mistake saying that my card has 2GB memory, it's 4GB and the Octane VR seems to be no longer avaiable to download?
Best regards
