- downloaded Octane
- extracted from the Octane-for-C4D-V3.06-win folder
- pasted the folder 'c4doctane' into /Program Files/MAXON/CINEMA 4D R18/plugins
- opened up Cinema
- Octane tab is not there
I am running Windows 10. Graphics card is a GEFORCE GTX 1070.
Help installing Octane into Cinema 4D R18
And forgot to read install notes in readme or from releases topic. You need to update c4d as written.
You also must install the stand-alone Octane application.torresfj wrote:- downloaded Octane
- opened up Cinema
Make sure you look through the plugins-folder. You want to use the correct version and not have extra folders/files in your plugin folder. If the actual files you need are nested in sub-folders...it won't work.
Read the documentation.
I am having the exact same issue. I've gone through all instructions including this. The only additional component is that Octane will show within Cinema, but you can not open the drop down. However it only show if I leave Octane R17 within the plugin....
Please help
Please help
let’s try in this way: ciao beppe
