I hope some guy can develop a plugin for Revit.
It's a huge market
OCT For revit
Even Autodesk can't make a decent renderer in Revit... Also, the lack of nice modeling tools and things like import/export options makes it difficult... I think Revit has a loooong way to go and nobody from Autodesk wants to help because it will affect 3dsMax sales.
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
RPC are just plain billboards? right? well they work fine as long as they can be exported as planes (I don't know about revit, but you can do it from max so I guess in revit should work the same). The only thing is that they won't follow the camera, just setup your camera and export and match the camera to the one in revit. It should look the same, the only problem would be to do another export for each camera setup.
Even if you can export RPCs (which I don't think that happens) they would look ugly... Believe me, when the quality is much better than medium mental ray, you can clearly see the difference...
