Octane Live Platform Testing Release Pre23_2
"someone" has done it.
						@YoonKyung: can you explain what is the problem you are facing ?
						Thank you for the update.
I tried some node change and LiveDb import and no crash to report.
Very good job.
Very good job.
p4 3,4GHz-2Gb Ram-GeForce 220 1Gb-Vista32bit
						When I pick a meterial up, from the meterial DB, or open a OCS file, OCTANE is crashing after a while.Nostromo wrote:@YoonKyung: can you explain what is the problem you are facing ?
I am using a machine which has 3x GTX480 and WinXP 64bit OS.
Win7 64 | 2x XEON  | 12GB | 8x GTX580
Could you try using just one card at the time to see if it works better ?
Also try first to use power of 2 resolutions.
I will test it, and let you know the result at tomorrow.Nostromo wrote:Could you try using just one card at the time to see if it works better ?
It's 12:20 AM in Seoul, KOREA and I am at home.
take your time
						- DigitalDouble
Thanks !
Finally I can run it without crashing every 2 seconds.
Win Vista x32 | 8800 GTS 512 | Xeon X3350 2.66GHz | 4GB
