Great but what kind of paths was there? Plugin checks these paths to find the textures . But first It looks for project folder and its sub folders and next for these paths if cannot find in first lookups.moebius wrote:I found the reason: I had in the C4D preverences all Harddrives. Ctrl+E > Files > Texturepathaoktar wrote: Like a joke! What are you using to freeze that soo long? Nothing should be longer than milliseconds
thanks aoktar
Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
- Domenicozzo
- Contact:
Weird, this latest version doesn't see my cuda devices, I've never had this kind of problem before, I went straight from 3.05.3 to 3.06-4.1
I'll try to update my nvidia drivers, even if 353.30 should work. Thank for this update, Ahmet, looking forward to test it out.
Domenico
Domenico
Pls check with more recent drivers. This version need cuda 8.0 and don't know but propably yours is not having that.Domenicozzo wrote:Weird, this latest version doesn't see my cuda devices, I've never had this kind of problem before, I went straight from 3.05.3 to 3.06-4.1
Domenico
- Domenicozzo
- Contact:
Yes, the new drivers fixed the issue. I've tried some scenes and this version looks much faster when loading the geometry: excellent job, Ahmet!
Thanks for first positive feedbackDomenicozzo wrote:Yes, the new drivers fixed the issue. I've tried some scenes and this version looks much faster when loading the geometry: excellent job, Ahmet!
what's happening with option?eyeonestudio wrote:Alt Gesture - Insert Still Buggy...
- a1.jpg (22.78 KiB) Viewed 5312 times
- JavierVerdugo
Hello Aoktar
I have downloaded all the sample scenes, but I don't see any example about triplanar node, I just try to find any information in the manuals, but there is none. I would like to know if you can share an example about triplanar, because I can't figure out how to use it.
It's a node which comes from core. You can check standalone topics. It's same.JavierVerdugo wrote:Hello Aoktar
- Frez121212
Getting an "invalid version" error on the network preferences even though both computers are running the same daemon version. (both have same standalone and plugin and i uninstalled the old daemon on both and installed the one from this test version on both)
Slave should have same versions as plugin. Invalid version means that not equal versions on both sideFrez121212 wrote:Getting an "invalid version" error on the network preferences even though both computers are running the same daemon version. (both have same standalone and plugin and i uninstalled the old daemon on both and installed the one from this test version on both)
