Hi guys, I could really do with some advice if possible.
I have a mesh from zbrush which is high geometry and even decimating it will kill modo so I am using a displacement map. The map works in the modo render and in vray, you can notice the holes where the eyes should be but when I render it in octane there is displacement but of little effect. I didn't play with any vray setting or add a vray material i just set the displacement distance in modo to 1m which is a normal workflow coming from zbrush. I have set up octane and adjusted the power of the map but still it doesn't give me the detail i get from vray or modo.
I looked around the forums and I found someone talking about octane and modo displacement so I tried changing the kernel settings and the octane preference settings the way they mentioned i.e. - modo render cache on/off and octane - enable/disable poly displacement and still it won't budge.
I would really like to use octane for this one as I only just bought it and I want to use it in my workflow.
Thank you to any guidance or advice, it will help immensely for future projects.
Gregg
Modo zbrush octane displacement map issue.
May I suggest trying with the new Octane 3.06 build of the plugin (pre-release available at viewtopic.php?f=34&t=55078&p=306464#p306464), since Octane 3.06 contains some displacement mapping improvements. Also be aware that very long, thin triangles with displacement may cause artifacts in Octane.
I will do the OSX build once the release is ready. I am aware of an issue with Octane 3.06 TEST 2, so it will need to wait until TEST 3.I am on OSX Mate. When will this build be available?
- Rafael-Vallaperde
Hi Raf. Very long, thin polygons can create displacement artifacts. Have you tried the latest 3.06 build? It contains some displacement mapping improvements.
- Rafael-Vallaperde
Hello Paul! Long time no see!
Yeah, this test has been generated on V 3.06 test 2.
The polygon spacing is pretty god(a la zremesher) it shouldn't be there because of weird ration on polygon's lenght.
Any ideas on this? it seems like a core problem and not a plugin issue.
Cheers!
Cheers!
Raf - I suggest you post an ORBX demonstrating the problem to the Octane Standalone 3.06 TEST 4 thread, where the Otoy devs can take a closer look.Any ideas on this? it seems like a core problem and not a plugin issue.
