Hi, I have an issue when rendering with PMC kernel.
Either using IPR or rendering to disk ( with or without mplay ) , indie systematically crashes when octane reaches the sampling target.
Image file is not saved.
has anyone experienced the same issue ?
Octane Plugin version : 3.06.0.0
Indie version : 16.0.504.20
PMC contstantly crashes Houdini at the end of every frame
C. RAM Capacity (i.e. 6 GB)
Tomorrow I'll release a new plugin build using the latest 3.06 Octane API available. Please check this issue with the new build, because some rendering crashes have been fixed in Octane since the latest release.
If you can reproduce this problem with the new plugin build, we can further investigate it. In this case, please attach a sample scene with this problem to try to reproduce the crash here.
Hi juanJo ,
I have downloaded the latest build ( using Octane API 3.06 TEST 2) , and the issue remains the same.
I am on windows 10 by the way.
Do you want me to send a sample scene ?
Windows 10 |NVIDIA RTX TITAN - 24GB| i9-9900K | 64GB RAM
