OctaneRender® for 3ds max® v3.06 TEST 3 - 4.31 [OBSOLETE]
Goldisart
go to slate material whit render PMC
in my opinion there is need to modify the test ... there's a critical error
paride4331
@mbetke
issue found,
workaround: set normal slot map to "none" when there's no map inside.
Elvissuperstar007
At me for some reason do not work fake shadows in glasses, transmission color
Elvissuperstar007
mbetke wrote:Hi, the release works well so far but I got some problems with the preview in Material editor.
I seems there is a strange line running over the material sphere. Never had it before. Just updated from 4.30 and opened the scene. :)
+1000
Elvissuperstar007
Where is infinite surface? I can not find.
paride4331
Hi Elvissuperstar007,
I did not find your issue, fake shadow and transmission seem to work.
Could you share a test scene with your issue?
paride4331
@Goldisart
I did not find your issue and any crash occured.
Could you share a test scene with your issue just before crash?
Elvissuperstar007
Glasses are spoiled, index artifacts
Elvissuperstar007
paride4331 wrote:Hi Elvissuperstar007,
If the material looks like this then does not miss, the distortion mapping works randomly, if you open scenes of version 3.05 all the glasses are distorted
paride4331
Return to “Releases”
