Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
VVG
milo_dude wrote:
aoktar wrote:
milo_dude wrote:Building geometry by spline using Sweep. When geometry update starts plugin is crashed.
Same trouble in test3 and 4.
3.05 works fine.
Yes it's crashing the renderer. We'll investigate it.
Thank you so much! It will be great!
no crash. and animation ok
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Yambo
Ahmet, render layer mask is broken, just not working in this version (generating blank frames). Are you aware of that?
Y
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Ahmet, render layer mask is broken, just not working in this version (generating blank frames). Are you aware of that?
Y
with png? I think it's about my changes to drop the using of embedded alphas with png.
Yambo
Y
Yap, basically if i'm loading some layer mask to after effects i can see only a full alpha.
Is there something i can do to workaround it? or just wait to the next version?
Y
https://yambo.me
Yambo wrote:
Y
Y
disable alpha and use rgb colors for matte
Studio21
Hi ahmet,
thx for your continues work!
are there any sample scenes for the new texturing modes (triplanar in particular)
Thx,
Guy
raulofs
Hi, Ahmet.
Thank you very much for your great effort to integrate this fabulous engine to c4d
I have some problems with test-4
When I open the node editor sometimes, it does not allow connecting one node to another and it make to freeze it, also randomly crash the plugin when I open other materials in the node editor :cry:
I leave the sample.
_BugReport.txt
(210.3 KiB) Downloaded 297 times
raulofs wrote:Hi, Ahmet.
I leave the sample.
I never use like that and didn't notified that. Yes i could reproduce this bug. Thanks!
Yambo
A while ago you implemented icons for the MIX material.
Why is that gone?
https://yambo.me
Studio21
i noticed that too
Return to “Releases”
