IPR renders fine. F9, F10 crash. Scene with heavy instances.
JPhi
I made a scene with lot of heavy instances.
LW renderer is ok with this scene. Octane IPR is ok with this scene (I succesfully saved images rendered with it).
But when doing F9 or F10 render, things goes wrong.
3 things may happens when doing this (using the very same scene everytime) :
- updating scene in gpu lasts forever and never complete.
- lw crashes after updating scene in gpu.
- octane stops after updating scene in gpu and asks me to look at the log file. The end of the log file is :
00:03:23 (0203.68) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:03:23 (0203.68) * OCTANE API MSG: -> failed to unload module".
But IPR renders successfully.
CONFIGURATION :
Lightwave 2015.3 build 2847
Lightwave SDK builds : 2847/2847
Octane plugin build : 3.05.3.0
Octane API build : 3.05.3
Octane DLL : 3050300
Dual Xeon - 96Go Ram .
Quadro K5000 (only for screen display - not used with octane).
TitanX Pascal (only used with octane - no screen or anything else plugged on it).
NVidia drivers : 375.86
I am short in time on this production, So thank you for responding me as soon as possible.
juanjgon
Perhaps you have a problem related to the motion instances motion blur, that is available only in the final rendering and not in the IPR. Do you know if disabling the motion blur fix the rendering problem?
The problem can be also related to the final render resolution, if it is too high (4k or 8k for example).
In any case, If you want to send me the scene, I could test it here. You could also try to render your scene with the latest plugin build 3.06.0.4. Perhaps this problem is already fixed on it.
JPhi
Thanx for your fast (instantaneous !) response !!!
I use the same (and very low) resolution (- this is still a test resolution -) with IPR and F9, F10 render :
I use motion blur (camera, lights, objects, instances; everything but deformation is on).
I setted motion blur in Lightwave to realistic, 100% (yes, needed in this case) 8 pass.
I setted 8 steps per objct and 8 steps per instance in octane.
And No multipass motion blur in octane.
And IPR renders instances motion blur very fine.
I'm not sure I can sent you my scene because I signed a confidentiality contract with the client. I will try to ask him.
Any suggestion on those settings ?
JPhi
I just tested without motion blur, and it does not crash (F9 rendering).
But what's strange is that with an other camera (which is part of the same scene), every things renders fine with F9 and F10 rendering and motion blur. Maybe this camera sees less instances (hard to say)
I install the latest plugin build 3.06.0.4 now. And will test and tell you what happens.
JPhi
I just tested it with :
Plugin build : 3.06.0.4
Octane API build : 3.06 TEST 4
Octane DLL : 3060003
I only changed the plugin, but not octane itself.
IS THAT OK ?
and same problem. Octane stopped after updating scene with this log (I copy only the end):
00:03:35 (0215.14) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:03:35 (0215.14) * OCTANE API MSG: -> failed to unload module
00:03:35 (0215.32) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:03:35 (0215.32) * OCTANE API MSG: -> failed to bind device to current thread
00:03:35 (0215.32) * OCTANE API MSG: device 0: failed to initialize resources
00:03:35 (0215.32) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:03:35 (0215.32) |
00:03:35 (0215.32) | ++++++++++++++++++++++
00:03:35 (0215.32) | +++ RENDER FAILURE +++ processing the failure callback
00:03:35 (0215.32) | Aborting rendering detected
00:03:35 (0215.32) | >>> Refresh preview window
00:03:35 (0215.34) | >>> Draw preview window progress bar
00:03:35 (0215.34) | ... Finish Rendering ...
00:03:35 (0215.34) | ... wait for the getPreviewImage function ...
00:03:35 (0215.44) | ... reset image callback ...
00:03:35 (0215.44) | Close and free scene, free buffer: 1, reset scene: 1
00:03:35 (0215.44) | ... freeBuffers
00:03:35 (0215.44) | ... setRenderTargetNode(NULL)
00:03:35 (0215.67) | ... update()
00:03:35 (0215.67) | ... getRootNodeGraph()->clear()
00:03:35 (0215.91) | >>> Refresh preview window
00:03:35 (0215.91) | >>> Draw preview window progress bar
00:03:35 (0215.91) | >>> Refresh preview window done
00:03:35 (0215.91) | Scene closed
00:03:35 (0215.91) | Close preview window
00:03:40 (0220.86) |
00:03:40 (0220.86) | Octane Render for Lightwave, end of log system
Nothing to do if I can't send you the scene ?
Yhank you for responding.
juanjgon
What happens if you set only 2 or 3 steps in the motion blur (change this parameter in the LW instance generators and in the Octane render options)?
This problem sounds to me to something related to have a lot of instances in near de same place (high instances density, with two or more instances in the same place), or to have very long motion blur trails. Perhaps you could play with the instances relax parameter, to modify a bit the instances distribution, and as I said before, use only 2 or 3 steps motion blur.
You could also try to render the scene using a bit less motion blur length, to see what happens.
I've seen also problems like this if you have 0 scale instances in one or more frames. Is it possible that any instance could have a 0 scale?
In any case, if you can send me the scene, I could try to find a workaround for the problem.
JPhi
I am near to find what makes this scene not renderable.
I have several layers in the T (texture) of the Weight of the instance generator (7 layers to be precise).
If I uncheck the 4 top layers (and keep the 3 bottom ones), I've got about twice more instances.
And with twice more instances F9 render is fine with motion blur.
I'll try to make a simplified scene with this problem and sent it to you tomorrow.
How can I send it to you ? Which email adress should I use ?
Thank you for looking at this problem which is a real production problem.
juanjgon
You can send the scene to my email [email protected]
asher
HI Juanjo,
I have the same issue here, I have reported it before, rendering fine in IPR but under F10 crashing at 99.9% and hanging LW.
no motion blur at all.
Images around 7K-8K.
IF gets to say 99%, i can still save manually via the IPR as PGN 8/16 bit.
But not the LW TIFF 24/32 FP file.
It happens with large scenes that have lots of instances ( vegetation ) HOWEVER, only 2.4GB VRAM use out of my 6/8 GB VRAM of series 10 pascal cards. ( 6Gb available becauseof the win 10 bug , not an issue on Win 7)
Since i moved from 780ti to series 10, i have not had any cuda errors, just that LW/Octane crash thing.
By the way, this bug WAS present on Octane 2 as well, i thought it had to do with my Vram and out of core stuff, but no i dont use out of core and have all my cards on Pascal series 10. Not even close in using so far 40% of available Vram.
May it be the 2D glow / post features ? is this done in the GPUs or on the host PC via CPU? Sometimes reducing the scene from 8000 x 4000 pixels to say 6000 would fix it.
GTX TITAN, TITAN Black, 780Ti
WIN 7/64
I7
Asrock Extreme 3 motherboard
LightwaveGuru
juanjgon wrote:What happens if you set only 2 or 3 steps in the motion blur (change this parameter in the LW instance generators and in the Octane render options)?
hi juanjo :)
i have here the same problem with a scene with tones of instances. With 3.06.04 this is happen...
00:02:51 (0171.74) | ... Check sizes for IPR
00:02:51 (0171.74) | ... Reading frame buffer
00:02:51 (0171.76) | Reading preview image successfully
00:02:51 (0171.98) * OCTANE API MSG: CUDA error 716 on device 0: misaligned address
00:02:51 (0171.98) * OCTANE API MSG: -> kernel execution failed(report)
00:02:51 (0171.98) * OCTANE API MSG: -> failed to launch kernel(ptBrdf2)
00:02:51 (0171.98) * OCTANE API MSG: device 0: path tracing kernel failed
00:02:51 (0171.98) * OCTANE API MSG: device 0: detected an error on render device! trying to recover...
00:02:51 (0171.98) * OCTANE API MSG: -> failed to deallocate device memory
00:02:51 (0171.98) * OCTANE API MSG: -> could not get memory info
00:02:52 (0172.06) * OCTANE API MSG: -> could not get memory info
00:02:52 (0172.06) * OCTANE API MSG: CUDA error 716 on device 3: misaligned address
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate device array
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate device memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate pinned memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to unregister pinned memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to unload module
00:02:53 (0173.77) * OCTANE API MSG: CUDA error 716 on device 0: misaligned address
00:02:53 (0173.77) * OCTANE API MSG: -> failed to bind device to current thread
00:02:53 (0173.77) * OCTANE API MSG: device 0: failed to initialize resources
00:02:53 (0173.77) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:02:53 (0173.77) |
00:02:53 (0173.77) | ++++++++++++++++++++++++++
00:02:53 (0173.77) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:02:53 (0173.78) | IPR: reset image callback
00:02:53 (0173.78) | IPR: wait for the getPreviewImage function
00:02:53 (0173.88) | IPR: free the OpenGL buffers
00:02:53 (0173.88) | IPR: rendering done
00:02:54 (0174.05) * OCTANE API MSG: CUDA error 716 on device 2: misaligned address
00:02:54 (0174.05) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.05) * OCTANE API MSG: device 2: failed to initialize resources
00:02:54 (0174.05) * OCTANE API MSG: device 2: failed to recover - giving up and switching device to failed
00:02:54 (0174.08) * OCTANE API MSG: CUDA error 716 on device 1: misaligned address
00:02:54 (0174.08) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.08) * OCTANE API MSG: device 1: failed to initialize resources
00:02:54 (0174.08) * OCTANE API MSG: device 1: failed to recover - giving up and switching device to failed
00:02:54 (0174.09) * OCTANE API MSG: CUDA error 716 on device 3: misaligned address
00:02:54 (0174.09) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.09) * OCTANE API MSG: device 3: failed to initialize resources
00:02:54 (0174.09) * OCTANE API MSG: device 3: failed to recover - giving up and switching device to failed
00:03:03 (0183.48) | IPR: close the IPR preview window
00:03:03 (0183.48) | IPR: finish render thread command
00:03:03 (0183.48) | IPR: abort render thread command
00:03:03 (0183.48) | Stop rendering scene
00:03:03 (0183.87) | IPR: abort render thread command finished
00:03:03 (0183.87) | Close and free scene, free buffer: 0, reset scene: 1
00:03:03 (0183.87) | ... setRenderTargetNode(NULL)
00:03:03 (0183.87) | ... update()
00:03:03 (0183.87) | ... getRootNodeGraph()->clear()
00:03:04 (0184.46) | Scene closed
00:03:04 (0184.46) | IPR: free the snapshots system
00:03:04 (0184.46) | IPR: IPR preview window closed
if i downgrade to V 3.05.03 the scene would render perfect :)
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
Return to “Lightwave 3D”
