PXL+DIRT grunge/dirt helper [2019/10/10 update]
Forums: PXL+DIRT grunge/dirt helper [2019/10/10 update]
Moderator: aoktar
Re: PXL+DIRT procedural dirt helper Cinema 4D & Octane
Postby 3dhermit » Mon Mar 13, 2017 11:03 pm
3dhermit Mon Mar 13, 2017 11:03 pm
Yes, thanks for the share , this is great , going to play with tonight !!! :D
3dhermit
Postby mrom » Tue Mar 14, 2017 6:39 pm
mrom Tue Mar 14, 2017 6:39 pm
this is really great! thank you! working fine in R16, 3063
edit: I'd say this is fantastic!
mrom
Postby pxlntwrk » Tue Mar 14, 2017 10:40 pm
pxlntwrk Tue Mar 14, 2017 10:40 pm
many thanks for words !
I will post a slightly improved version (i hope) when i have some time for that. :D
Noodles mat
another test
ciao ;)
pxlntwrk.net
pxlntwrk
Postby mrom » Tue Mar 14, 2017 11:00 pm
mrom Tue Mar 14, 2017 11:00 pm
Thanks again. An option for more stickers would come in very handy :D
mrom
Postby pxlntwrk » Wed Mar 15, 2017 11:11 am
pxlntwrk Wed Mar 15, 2017 11:11 am
@mrom: i will post soon anther version with one more sticker slot, but its very easy to do with material stacking if you need, more.
thanks
pxlntwrk.net
pxlntwrk
Postby jsuarez388 » Thu Mar 16, 2017 5:56 pm
jsuarez388 Thu Mar 16, 2017 5:56 pm
Hey,
First of all this seems like a great script! such a time saver. Unfortunately I'm testing in R17 and Octane V3.05 and I think it's not working. Even the test scene you provide in the download doesn't react to things I change in the script.
Maybe a tutorial on how to correctly use the script would come in handy. I noticed that the script creates a bunch of MIX materials, but only because I know that with scripts sometimes materials are hidden.
I did drag a new material to the base, but again, it doesn't update at all for me. Maybe i'm just doing something wrong.
Let me know, but looks great though!
My system specs:
AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
jsuarez388
Postby pxlntwrk » Thu Mar 16, 2017 7:31 pm
pxlntwrk Thu Mar 16, 2017 7:31 pm
hey jsuarez388 !
I'm really sorry that it does not work for you,
i think it will not work with versions below 3.06 because "ADD" and "SUBSTRACT" nodes are used several times.
and yes like you can see with nodegraph pix above there is a total of 5 mix mat (I think lighten things in the future )
I work with r18 but i add already some returns that's working with r15 and r16
you can find more info ( french) there >> http://frenchcinema4d.fr/showthread.php?81447-Octane-Dirt-grunge-Helper-(WIP)
Anyway as I already said I will post a version a little improved, as soon as possible.
thanks for testing
ps/ its simply an xpresso controlling Octane Mixmat etc, and bring some parameters togetehr in UserData ... python scripts (sources are at the beginning of each) are used for the functional part (UI) and not at all for the management of the materials.
pxlntwrk.net
pxlntwrk
Postby nicolectro » Sun Mar 19, 2017 12:43 pm
nicolectro Sun Mar 19, 2017 12:43 pm
Un énorme merci pour ce travail fantastique que tu partages avec les incapables du code comme moi. Script indispensable s'il en est !!
nicolectro
Postby VVG » Sun Mar 19, 2017 1:11 pm
VVG Sun Mar 19, 2017 1:11 pm
Thanks! this is great and handy!
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Re: PXL+DIRT grunge/dirt helper (2017/05/27 update)
Postby pxlntwrk » Sat May 27, 2017 8:35 pm
pxlntwrk Sat May 27, 2017 8:35 pm
hi,
new version
update on top of the first post..
viewtopic.php?f=30&t=59827&hilit=pxl#p306211
Cheers
pxlntwrk.net
pxlntwrk
PreviousNext
Return to Maxon Cinema 4D
Users browsing this forum: Google [Bot] and 9 guests
Sun Jun 16, 2024 12:18 am [ UTC ]
