Phoenix fd 3 support.
It works!
Thank you all for all your help
The smoke was very light.
Hopefully you guys can get the octane volume modifier to work soon with phoenix 3 including Phoneix 3 wet map procedural textures, foam, splashes, mist, bubbles.
The hardest part now is if we simulate a building fire is to later place imported VDB octane volume precisely where phoenix 3 fire simulation happened
not sure if octane is not ready for phoenix 3 but we have a scene where one sphere is flying and spraying fuel and the other one is on fire catching that fuel on fire. But when we render we have fuel on fire (it has not been lit yet) and fire is not rendered at all Please help. Thank you
here is the scene
- test tun.zip
- (26.25 KiB) Downloaded 270 times
Coibook, I am also using PHX for max...and I also found the positioning to be troublesome, but I managed to get a quick fix...just align the octane volume to the pivot of the PHX Grid and rotate the octane volume - 90 on the X...at least me it worked very well. this short video was rendered in octane and in this case i had also linked the GRID to the car and did the same with octane volume... the dust is low rez but the test was just to see if it could be done!coilbook wrote:It works!
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe wrote:Coibook, I am also using PHX for max...and I also found the positioning to be troublesome, but I managed to get a quick fix...just align the octane volume to the pivot of the PHX Grid and rotate the octane volume - 90 on the X...at least me it worked very well. this short video was rendered in octane and in this case i had also linked the GRID to the car and did the same with octane volume... the dust is low rez but the test was just to see if it could be done!coilbook wrote:It works!
Thank you! However we have two main problems:
1. If fuel is enabled and we also have a separate fire source fuel is also on fire before it is even lit.
2. If fuel is renderable, fire is not rendered anymore. Empty space. Please see image attached you can see lit fuel but empty place where fire/smoke is supposed to be.
We want fuel to render as smoke/gas and not fire and fire to render as fire and not be missing.
Hi..yes I understand... i hope it gets fixed soon!
PHX is a badass tool
coilbook »
most likely the problem is the materials I tried and I did not have problems
https://www.youtube.com/watch?v=CWJN7Gfeht0
Goldi,
care to share the scene so we can study? or at least explain how to do it?
Nildo
Nildo
