Multipass Renders - Noisy Beauty Pass in After Effects
Ferdinand13
Hi there,
I'm rendering an animation in Octane Render for C4D (3.05.3) using Path Tracing to create a series of Multipass EXRs. The resolution is 1920x1080 and at 1200spp in the C4D Picture Viewer the overall Beauty Pass looks good.
However, when I open those EXRs in After Effects and break out the Beauty Pass via the EXtractoR effect, things don't look as nice anymore.
There's a whole lot of noise, that didn't show up in the C4D Picture Viewer.
Any idea, why this happens? Looking forward to hear your comments.
Custom PC, Intel Core i7-6800K, 48GB RAM, 3x MSI GeForce RTX 2080 Super Seahawk EK, Windows 10
Razer Blade Pro 17, Intel Core i7-10875H, 32GB RAM, 1x NVIDIA GeForce RTX 3080, 1x EVGA GeForce GTX 1080 Ti Hybrid (eGPU), Windows 10
jsuarez388
Recently found some problems with exporting 32bit EXRs myself. My issue was with multilayer EXR and info passes, after frame 80, EXR would render black, but anyways...
I am curious, since you are saying that you applied Extractor in After Effects and extracted the beauty pass, i'm assuming that you are also rendering a multi layer EXR... if this is the case did you try adding a Levels effect and playing with it to see if the noise goes away?
With EXR once you export the beauty pass that means (if I am not mistaken) that this is not tonemapped color space, like it is in the Live Viewer in C4D, once extracted it is linear therefore things might look a bit different and would require some color correction or even compositing of other passes (lights, reflections, etc)
Try it out and let me know what you come across, I am interested to see where this goes with EXRs
My system specs:
AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
slepy8
If you render to EXR with Render Layer Masks set for some objects you don't only get the beauty pass and layer masks.
You get additionally beauty pass images with alpha according to Render Layer Masks.
So in overall if you have for example 4 Render Layer Masks set, you'll get 5 beauty passes.
I realised these additional beauty passes are noisy AF recently and found no solution to this.
Just leave "Save Beauty" ON and composit this Beauty Pass with Render LAyr Mask.
Just be sure to choose the right beauty pass in Extractor.
slepy8 wrote: So in overall if you have for example 4 Render Layer Masks set, you'll get 5 beauty passes.
I've removed these additional beauty passes which come with RL masks in my dev build . Are they necessary/usefull somehow? What you think?
slepy8
IMHO they are not needed.
They just take hard drive space.
Most people are compositing using alpha masks however..
slepy8 wrote:IMHO they are not needed.
I suppose so thanks!
jsuarez388
slepy8 wrote:If you render to EXR with Render Layer Masks set for some objects you don't only get the beauty pass and layer masks.
No, this is not the issue. I didn't check Render Beauty in my mutlipasses. I only needed the Layer Masks (object buffers) to be able to composite in After Effects. The multilayer EXR worked great for 80 frames or so, after that it's all black, and this didn't just happen with the layer masks, ambient occlusion and light pass had the same problem. I had to re-render to PNG sequences and then it worked, I even tested it out rendering individual EXR sequences and it worked too, so I think there might be a bug or something when rendering multilayer EXRs out of Octane.
As for your problem, did you render a tonemapped pass out of cinema? meaning not the beauty pass from the multipasses in Octane, but the actual image composited with AO, shadows, reflections, etc - does this come out grainy?
My system specs:
AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
Hi jsuarez388,
Just talking about issues that will not help to detect if there's a problem. Don't you mind to send your scene? It's way how we check the problems.
jsuarez388
aoktar wrote:Hi jsuarez388,
Hey Ahmet,
Sorry i didn't mean for this to seem like i'm just complaining. Not at all. I was just trying to expose the similar problem I had with EXRs to Ferdinand13 and also tried to give him some advice.
Speaking about my scene, yes I can send you a scene for you to test. I'll let you know in my post, since you already replied there as well, i just didn't have time to upload it till now that the project is done.
My system specs:
AMD Ryzen 7 1700
GeForce GTX 1070 x2
16GB Ram
Running Windows 10
Octane Render V4
Hey Ahmet,
Sure i know that. Just we need more direct feedbacks from users. I believe making a better software will make you happier. Thanks and i'm waiting for a scene.
