Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
bododge
I was worried about upgrading to Sierra, but it turned out to be fairly easy, and I think my Titans are actually running smoother than before. I've tried latest build. I don't have anything constructive to add, just chiming in to say I appreciate all the changes that are coming Ahmet. I know some people on this forum are demanding, and expect their requests to take priority. Thank you for working hard to answer our questions and listen to what people want. You are doing an amazing job. People who have experience with other render engines and forums know how good we have it here.
Thanks for being a great dev at Otoy.
bododge wrote:I was worried about upgrading to Sierra, but it turned out to be fairly easy, and I think my Titans are actually running smoother than before. I've tried latest build. I don't have anything constructive to add, just chiming in to say I appreciate all the changes that are coming Ahmet. I know some people on this forum are demanding, and expect their requests to take priority. Thank you for working hard to answer our questions and listen to what people want. You are doing an amazing job. People who have experience with other render engines and forums know how good we have it here.
Thanks for motivation, really! This development have to be handled very carreful on every steps. So that's sometimes very stressful. And yes priorities are different for everyone. Even at this time somebody will come up with unexpected requests. Some of these are really simple to add in a short time but some are exactly not. We have some todo list and it's mostly from user requests and my ideas. I'll try to do most of these when they are possible. And reason of test builds are not using everybody as a tester. Just gathering feedbacks and improve features and stability with your contribution. I believe that's mostly for you not me. I can write this plugin as offline and publish a stable release after several months. Believe this is best/fastest way that i know.
eyeonestudio wrote:<<< Render failure detected!!! >>> :?
3.06 T2 (caching system test version)
With Environment Fog
How it happened in details?
eyeonestudio
I did not do anything. It just occurred while moving the viewport. that's all. :(
3.05.3 Still fine here.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio
If possible, Could you make Thumbnail-View? :)
slepy8
+1
- thumbnails would be very helpfull. I was going to make a post about it but i thought it's not a good time ;)
eyeonestudio wrote:If possible, Could you make Thumbnail-View? :)
You could make actually.
Josef
yes this is already in with right click :)
eyeonestudio
That is it. :( I did not use before.
However, the real-time response is disappointing.
It would be better if you could some node preview it by default.
(RGB Specturum, Gaussian Specturum, Float Texture)
I know this is WIP.
Thank you. :P
It would be better if you could preview it by default.
I know this is WIP.
Thank you. :P
It's not possible to be faster. Because they are previews which are generated by gpu. And connected node's previews will be updated. It's extra slow-down. You can see colors in gui else of gaussian spectrum.
Return to “Releases”
