Symetrized geometry problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
HHbomb
I just saw that with 4.30 symetrized geometry ( specular material ) have a refraction problem. Higher is the Index of refraction more visible is the problem.
Glass have thickness. with IR = 2.0
Hope that can be solved quickly.
EDIT :
After some research,s the problem occur if :
- the object is not movable proxy
- specular have smooth unchecked
paride4331
Hi HHbomb,
have you tried to flip the normals?
HHbomb
Hi, thanks for reply. But as it is instances I can't flip normals.
paride4331
Hi HHbomb,
Could you kindly share your file please?
HHbomb
Hi, here is a file.
pb.zip
(163.05 KiB) Downloaded 241 times
paride4331
Hi HHbomb,
as you can see in the screenshot, it is a normal issue.
HHbomb
Ok, ..
So I can't symetrize instanced objects in Octane render ?
paride4331
Hi HHbomb,
This issue seems to be solved by making it movable proxy. I'm investigating to find out about this.
I'll let you know as soon as I will understand.
Return to “Bug Reports”
