So I installed both Standalone and a Win7 x64 machine at home and everything work.
Then I installed the same files on a Win10 x64 machine at my workplace. I could log into the Standalone version and everything works including the liveDB.
But on Rhino, I could not log into Octane no matter what. I am running Rhino SR13 the latest from McNeel. It keeps giving me the 'could not connect to SSO server' message.
The weird thing is that on the Win10 work machine, I could still log into the Octane Standalone version without problem!? Is that a plugin problem or an Octane problem?
I have tried uninstalling everything and reinstalling everything more than 3 times and still no go.
I have also looked into my Windows Firewall and nothing from Otoy is blocked, nor anything from Rhino.
Re: SSO server Problem.
Hi - what version of Octane Standalone and what version of the Rhino plugin do you have installed? It sounds like a firewall issue to me (firewall is blocking Rhino by not Octane Standalone).
Hi Paul,
Thanks for your reply. I did blocked Rhino from updating because I want to keep the stable working version. As I mentioned, I unblocked it but I forgot to RESTART!
Now, Octane is working.
Another question though, somehow if I use the local ISP I cannot login to either the Standalone or the Rhino version of Octane. Even now, I need to use my mobile wifi in order to successfully log into the system. Is there a specific port that Octane is using that can be blocked by my ISP? Can we change the port number in the registry or something?
Thanks.
Thanks.
I will ask an Otoy dev to respond to this.Another question though, somehow if I use the local ISP I cannot login to either the Standalone or the Rhino version of Octane. Even now, I need to use my mobile wifi in order to successfully log into the system. Is there a specific port that Octane is using that can be blocked by my ISP? Can we change the port number in the registry or something?
Hi Paul,
I have not gotten a reply from Otoy yet. And now I encounter a new challenge.
I have tested the Rhino plugin on two different computers at my HK workplace to make sure the license can work on two different computers and it did.
Now that I have used the same license on an installation across the border (you can say another country). I cannot sign back into my original machines!
It says that the license is currently in use. Do I have to sign out every time on a particular machine that I have used Octane?
I have asked Otoy again if they can respond to your issue. Sorry for the delay.
This error generally shows that there's something blocking communication between Octane and our server. Usually this is a firewall issue and you need to make sure all communications via HTTPS (TCP port 443) are allowed for both standalone, daemon and your Octane plugin host application (Rhino in your case).slimer wrote:could not connect to SSO server
This means that all your licenses are used at the time Octane tries to get activated upon startup. Licenses are released automatically (unless you are using offline licensing mode) when either standalone or the host application are closed. Note that if the application hangs or not closed gracefully, the licenses may remain in use even when your computer is switched off.slimer wrote:All of the licenses for this product is currently in use
In order to understand how licensing works I recommend taking a look a this link:
https://docs.otoy.com/manuals/products/ ... et-access/
In the future if you need to check what licenses are currently available you can do it here:
https://render.otoy.com/account/octanelive.php?
I hope that helps.
