Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
VVG wrote:
Cheiser wrote:Got crashed everytime in complex scene. WIP-1 or WIP-3 doesnt matter.
With stable builds its ok. But i think its problem with my scene. But stable its ok, strange.
+1
no crash. Volumetric rendering scene.
<<< Render failure detected!!! >>>
error happens in different places. for example, when the turn POST effects during rendering LV
nvidia driver 378.66. no overclocking video card
in standalone 3.06 and C4D 3.05.3 - works fine!
do you have render passes activated?
Cheiser
Yes I have. Diffuse, reflexion, ao, emitters. Scene have a lot of polygons. But stable version render it without any crash. Sad.
Cheiser wrote:Yes I have. Diffuse, reflexion, ao, emitters. Scene have a lot of polygons. But stable version render it without any crash. Sad.
can you check without passes? Any extra info is worth.
Cheiser
It's OK in Lv if I'm not moving on timeline. If I do scroll through timeline with Lv active - it's says render error. And I need to restart cinema 4d. If I start render this scene to picture viewer - at random, frame cinema crash. In wip3 even bsod. Other scene seems to be OK, but I don't sure about it. I,ll will launch some tests soon to provide u extra information. Octane console errors, bsod report etc
Cheiser wrote:It's OK in Lv if I'm not moving on timeline. If I do scroll through timeline with Lv active - it's says render error. And I need to restart cinema 4d. If I start render this scene to picture viewer - at random, frame cinema crash. In wip3 even bsod. Other scene seems to be OK, but I don't sure about it. I,ll will launch some tests soon to prove u extra information. Octane console errors, bsod report etc
cuda errors with passes is a known problem with this sdk. Note that's a test sdk. Extra info about settings/passes/etc.. is fine always.
Cheiser
Also I'm using 970 and 1070 cards. But even with 1070 alone it crashes. Passes have a correct visual info, no glitches etc. No matter AS turned On or turned Off. I rendered different scene with Wip1 and as and it's doing OK. Boosted from 2:00 min to 1:00 per frame, awesome. I'll launch some test and hope it's will be fixed someday. AS is awesome
VVG
+1
no pass.
i have more logs. If don`t touch anything in scene or octane settings (post effects, region render, ets) - rendering ok
scene like this.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
eyeonestudio
Tri-Planar Node Test.... :)
It's Working.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio
Q:
1
I want to know how to use "NodeGraph" node.
2
What is the concept of COMPARE-NODE?
What is the situation for? :?
Josef
eyeonestudio wrote:Tri-Planar Node Test.... :)
It's Working.
looking good :)
Return to “Releases”
