Hello,
i know this problem has been discussed before,
but i just installed the demo version of turbulence FD
(it's the 1419e version) and have the message
TDF mismatch client 3 - server 0 with nothing showing up in the IPR.
I'm using the 3.0500 Octane version,
is there a know issue between these two versions?
What can i do to fix it?
Thanks a lot for your help
Olivier
TFD volumes doesn't show in IPR
I have exactly the same problem here (same versions). Is there a way to fix it?
The plugin is compiled using the TFD 1416 build API. It is weird, because there are no changes in the API between the 1416 and 1419 versions, so the plugin should work with the latest one.
I'm not sure what means the "e" in the "1419e" build ... the current one to download as costumer is the "1419", without "e". Anyway, I'll update the API used by the plugin to the latest one for the next build. I suppose that this should fix the problem.
Thanks for reporting this issue.
