Crash On Animated Package Export With Instances
Lobster_Johnson
I have a scene with many clones of a complex animated element that I need to export for use in Standalone.
If I have "Render Instances" turned on, or make the Cloner editable (creating instances set to "render instance"), the export will crash just after finishing all frames. I have pulled up the log for octane and the console, but they do not show any errors.
When it crashes, the Orbx export dialog always shows one frame past the end frame i.e. "Export frame:1001 of 1000"
The crash does not happen if I turn off render instances, making it export all the geo which takes up more room in an already large standalone file.
Can anyone shed some light on what might be going on?
It may be very big file and a crash at end.
Lobster_Johnson
aoktar wrote:It may be very big file and a crash at end.
I think you are right to some degree, but there is something else up.
If I reduce the frame range, I can get it to export. But why does it export fine without instances with a much larger file size?
Somehow plugin can think the mesh of instances get updated on every frames. And write new mesh for every frames. Check it in LV if you see recreation of meshes on every frames.
Lobster_Johnson
Here is what I'm seeing in the Log:
SET SKY=0x0000000000000000
ENV CALC=0 force=0 updated=0 envtag=0x0000000000000000
0 GENERATE new instance base mesh:0x0000000000000000 objects:Crosswalk Kid-Car, Car Arrows 1, Null, Null 0, Plane.1, Null 1, Null 2, Null 3, Null 4, Hand 1, Extrude, Cap 1, Cap 2, Hand 2, Extrude, Cap 1, Cap 2,
1 GENERATE new instance base mesh:0x0000000000000000 objects:Null 0, Plane.1,
2 GENERATE new instance base mesh:0x0000000000000000 objects:Animation Group 0, Walk Arrows 2, Null, Walk Arrows 1, Null, Car Arrows 1, Null, Arrows 0, Plane, Plane.1, Arrows 1, Plane, Plane.1, Arrows 2, Plane, Plane.1, Arrows 3, Plane, Plane.1, Arrows 4, Plane, Plane.1, Hand 1, Extrude, Cap 1, Cap 2, Hand 2, Extrude, Cap 1, Cap 2, Walker 1, Extrude, Cap 1, Cap 2, Walker 2, Extrude, Cap 1, Cap 2, Stop Sign R, Sweep, Cylinder, Stop Sign L, Sweep, Cylinder,
3 GENERATE new instance base mesh:0x0000000000000000 objects:Animation Group 0, Walk Arrows 2, Null, Null 0, Plane, Null 1, Plane, Walk Arrows 1, Null, Null 0, Plane, Null 1, Plane, Car Arrows 1, Null, Arrows 2, Plane, Plane.1, Arrows 3, Plane, Plane.1, Arrows 4, Plane, Plane.1, Hand 1, Extrude, Cap 1, Cap 2, Hand 2, Extrude, Cap 1, Cap 2, Walker 1, Extrude, Cap 1, Cap 2, Walker 2, Extrude, Cap 1, Cap 2, Stop Sign R, Sweep, Loft.2, Stop Sign L, Sweep, Loft.1,
[GI]  Updating.....
Singular matrix:
   0.000 0.000 -0.000 -229.484
   0.000 0.000 -0.000 5.191
   -0.000 -0.000 0.000 172.192
Singular matrix:
(MORE SINGULAR MATRIXES...)
I mean Live Viewer. If you see lot of updating process between frames. This may show many changes on meshes and big file at end. Of course i don't have idea about resulted orbx.
Lobster_Johnson
Ah, I see.
There doesn't seem to be a lot of updating, but I don't know for sure.
What about a different method for scattering, maybe in Standalone. Is there a way to generate a CSV file for scatter positioning from C4D?
Lobster_Johnson wrote:Ah, I see.
my advice to convert child objects to polygons in cloners with render instances. This will avoid to recreation effect. Another trick is to don't use subdivision surfaces. Use object tag's subdivision to get smaller export files.
Lobster_Johnson
I have already converted everything I can to polygons, but I still have some parts that contain Cloners with animation on them.
So what should I do about cloners within cloners?
Lobster_Johnson wrote:I have already converted everything I can to polygons, but I still have some parts that contain Cloners with animation on them.
Not so much to do i think! Best to divide your scene to a few parts to export.
