slave installation fail "all of your licenses ...
miohn
are currently in use!
but this is not true!
I have 3 licenses and after removing one PC I want to start the slave on
a new built PC. But that is definately the 3. one.
So I have 3 Computers and 3 licenses
Whats wrong?
thanks
Mike
glimpse
Hi, Mike.
Please log into Your account on OTOY & release those licences. At least check if they are free. Sometimes for some licences do not get released, because the program do not turn off or licencing server is not reached /maybe some firewall or server issue/ etc.
So, make sure those licences are in a shape to be used.
miohn
Hi Tom,
all three licenses have status "unlook"
Not sure what this means. So they should be usable or do
I need to click on to unlook them, because the other 2 PCs are working?
Or do I need to unlook all 3 licenses?
I have only 5 left (not sure what this means)
regards
Mike
miohn
holy shi.!!!!!!!
now my second license is deactivated!
I paid for 3 licenses and I want to get 3 licenses!
Anyone from Otoy reading this?
I need to render!!!!!!!!!
thanks
Mike
Hi Mike,
on OctaneLive you can check the name of the machine where the licenses are active, and use the Unlock button for the old machine only.
In this way you should be able to activate on the new machine. The counter will be reduced by one and will be reset after a certain period of time.
Alternatively, if you still have access to the old machine, you can start one of the latest Standalone and sign-out from the Account window. In this way, all the active licenses in the specific machine will be deactivated.
ciao beppe
mojave
Just unlock one of the licenses so it's again available. Usually licenses are released automatically but if you happen to switch off your computer and the host application or Octane were not closed gracefully that might have caused that.
Here's the documentation with all you need to know about how the floating licenses system works:
https://docs.otoy.com/manuals/products/ ... et-access/
miohn
sorry guys but I don't understand!
Now all 3 licenses have status "unlock" but I still cannot start slave or
standalone on the second PC.
What should I do?
Should I turn off all 3 PCs and restart them all?
Thought that the new licensing-system make things easier. :roll:
thanks
Mike
glimpse
Hi, Mike,
When You see this red button near Your licence
it means that Your licence is in use. or if You're are not using it, that it hasn't been unlocked properly (there might be different reasons).
If You want to use network rending You need to install install daemon (You should find this with standalone installation)
it will ask You few questions & then You render node will be ready
so, if Your all licence are in use, 1st make sure You're not using them by accident - let's say software is still opened on any other device.
if You checked that, press on UNLOCK button to release licence.
* Keep in mind that You have 5releases before You need to get in touch with OTOY to have more of them.
If You turn off Your system & program, this should release licences automatically,
please make sure it works as intended by checking status online.
if You have any issues, feel free to write back & we'll help to solve this.
miohn
I'm getting nervous now!!!!
As before I have 3 PCs One Main WS and Slave 1 and Slave 2
I changed Slave 2 with a new PC
After the first license error message I unlocked Slave 2 (the new one)
and the result was, that Slave 1 got deactivated.
I then unlocked Slave 2 with the result that I got status "unklock" for all 3 PCs again,
but now I get the license-error-message on Slave 1
I have shut down all 3 PCs now and I deinstalled all slave deamons and again reinstalled all
deamons.
But I still get license-error-message on Slave 1 !!!!!!!!
I have lots of renders to do and if one slave fails .....
Like months before I still have 3 PCs and 3 Licenses
please help!
regards
Mike
miohn
super!
still cannot activate Slave 1 again!
On the last remaining Slave 2 (the new built) I now get tons of errors.
I thing about jumping out of the window!
this is on Slave 1
"it sais, that all 3 licenses (3,3) are in use , but only 2 are listed"
What the hell ....
regards
MIke
