Hi Guys,
we encountered a strange behavior of the Mix Material. The Mix is driven with a Cinema Gradient.
When I Batch render in 2 different Takes (over C4D Take Manager, Render all marked Takes), the Mix Material breaks and renders only one Material.
Rendering in a singe take and everything works fine.
Descriptive Image:
https://ibb.co/dQAdYv
I attached the scene so you can test for yourself.
Here our specs:
- Win 10
- C4D 18.039
- Octane 3.04.5 R2
- 4x GTX 1080
Mix Material with Cinema Gradient over Take System
C. RAM Capacity (i.e. 6 GB)
- motionstar
- test_bug.zip
- (108.52 KiB) Downloaded 191 times
3.04.5 is not latest and i can't see what's wrong on your scene with dev build.
- motionstar
EDIT: You have to Render out the two Takes over the Take Manager, if you haven't done that yet.
Thanks for you Reply, unfortunately we hesitate to update in the middle of our Project. But i will test with latest version of Octane.
I could see what happened after you described. I'll check it!
