Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
Here is new topic for version 3.06. This is still WORK IN PROGRESS and based on a TEST SDK( 3.06-TEST3).. And I don't recommend it for COMMERCIAL jobs at the moment.
You can find a detailed description of the new 3.06 features of Standalone in this thread: viewtopic.php?f=33&t=60014
This is the OctaneRender matching the plugin Standalone 3.06 TEST 3.
Changes since 3.05.3
- NODE EDITOR improvements for daily usage and addons as insert in insert/extract/delete, groupping(aka. nodegraph), snapping.
- Node Editor: Support for drag/drop from/to content browser. Saving as presets. Several fix/improvements.
- Fix for name/layer tab for nodes.
- Fixes on motion blur engine.
- Increased texture inputs to 64 in gradient.
- Add/Subtract/Compare/Triplanar nodes has been added.
- Displacement: Filter parameters.
- Adaptive sampling added. Noise pass is activated when it's selected. See for detailed explanation: https://inlifethrill.com/adaptive-sampl ... ne-render/
- Camera bokeh parameters.
- New Motion blur option for generating motion blur from speed vector of vertices. This will allow to generate motion blur on fluid meshes, etc... It's tested with latest RealFlowC4D plugin and worked well.
It's possible to link the Vertexmaps as component of vertex speed vector. It requires three vertexmap for X,Y,Z component of vertex speed.
- Bug fixes, small improvements for several stuff.
- Performance improvement on algorithm for movable geometries
- Texture caching (can be switchable by a caching paramater in settings/other). Any images in materials will be kept alive for Octane caching mechanism. So after usage of images in materials that will not be reloaded for later usages. Effect is faster material creations with images which are in cache. Caching will be resetted when active scene switched or closed.
- Fix: Alpha in z-depth passes.
- Fix: Update issue on TextureTag/Camera Mapping
WINDOWS REGULAR TEST-3.1 BUILD
https://render.otoy.com/customerdownloa ... est3.1.zip
OSX REGULAR TEST-3.1 BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
SUBSCRIPTION TEST-3.1 BUILDS:
WINDOWS: https://render.otoy.com/customerdownloa ... est3.1.zip
OSX: https://render.otoy.com/customerdownloa ... Macosx.zip
OctaneRender™ Standalone 3.06 TEST2
viewtopic.php?f=33&t=59760
Requirements:
-You'll need to update your Cinema 4D to latest versions(16.050, 17.053 or 18.039). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(at least 344.x(Cuda 8.0)
MANUALS: (extract to c4doctane dir.)
Offline HTML: https://render.otoy.com/plugindownloads ... ual-V3.zip
Online manual: https://docs.otoy.com/#60Octane%20Rende ... r%20Manual
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R16.0, keep only "c4dOctane-r16.cdl64" and delete c4dOctane-r15.cdl64, c4dOctane-r14.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
zinogino
Awesome!
pixonoid
Silverwing wrote: Also I like the idea of using some sort of search list like in Houdini to drop down nodes. I spend too much time searching the left hand list for the nodes I need. (Although you have made it as smooth as possible by coloring the nodes)
i second that, what could help alot would be to make the spacings larger between the groups. People would learn a recognition pattern very fast by scanning the amount of entrys per group. I also thought about icons but i honestly don't think they would make anything better here.
maybe something like that (rough and dirty)
and when you open the slate editor the topics are all gray and colors kicks in once you press atleast one of them (3.05 and 3.06 test) making it overlayed afterwards :)
Keep up the Awesome work.
GPU - 2x Gigabyte GTX1080 8GB + 1x EVGA GTX980 TI sc | CPU - Intel i7-4790K@ 4.0GHz | OS - Windows 10 Pro 64-bit - 32 GB RAM | 3Dsmax - many
maciek3d
not working with cinema4d r15 :(
NikAinley
The adaptive sampling looks amazing :) I'd love to give it a go but for the first time I'm having trouble upgrading to a new version.
So I upgraded the standalone to the 3.06 test version and my plugin to the one linked at the top of this thread.
When I try to start rendering I get a render failure :( I've attached the log of the errors I get when I try.
C4D doesn't crash, it just doesn't render anything else either. It doesn't even matter if there's nything in the scene or not, or which kernel I use.
I tried opening a test scene in the Standalone app and that renders fine so it seems to be something on the plugin side?
Other info:
Windows 7
Cinema 4D R18.041
Nvidia Drivers Version 376.51
1 x GTX Titan X
2 x 980 Ti's
Any help would be much appreciated.
octane 3.06 TEST 170221 130420.log
Octane log
(17.02 KiB) Downloaded 467 times
All cuda errors are belong to renderer. Plugins is working cpu code not gpu.
NikAinley
Ok I thought that might be the case. Any idea why it would work in Standalone but not the plugin then?
NikAinley wrote:Ok I thought that might be the case. Any idea why it would work in Standalone but not the plugin then?
I believe that you don't try same things. Or it's still not a plugin problem. Just may occurs due different usage of Octane SDK in plugins. Not worth to discuss what's main reason. Better give some scenes or details about your scenes. I'm also seeing similar cuda errors with this test sdk on render passes or AS, etc...
NikAinley
Thanks for the reply!
I don't think it would help to share a scene seeing as it happens in any file I open, even a new scene with absolutely nothing in it. For the moment I have to roll back to an older version as I need to do some renders but will try again when I get a chance.
Well! I added small space between left buttons. Also it's possible to change size of buttons/fonts from settings. Next step is to add a search field.
Return to “Releases”
